Datasheet HMC648ALP6E (Analog Devices)
DescriptionGaAs MMIC 6-Bit Digital Phase Shifter, 2.9 to 3.9 GHz
Pages / Page8 / 1 — HMC648ALP6E. GaAs MMIC 6-BIT DIGITAL. PHASE SHIFTER, 2.9 - 3.9 GHz. …
File Format / SizePDF / 538 Kb
HMC648ALP6E. GaAs MMIC 6-BIT DIGITAL. PHASE SHIFTER, 2.9 - 3.9 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC648ALP6E Analog Devices
HMC648ALP6E
v01.0217
GaAs MMIC 6-BIT DIGITAL PHASE SHIFTER, 2.9 - 3.9 GHz Typical Applications Features
the HMc648ALP6e is ideal for: Low rMS Phase error: 1.2° t • eW receivers Low Insertion Loss: 5 dB M • Weather & Military radar High Linearity: +45 dBm Positive control Logic • Satellite communications 360° coverage, LSB = 5.625° e - S • Beamforming Modules P 28 Lead 6x6mm SMt Package: 36mm² • Phase cancel ation y t
t the HMc648ALP6e is a 6-bit digital phase shifter c which is rated from 2.9 - 3.9 GHz, providing 360 u degrees of phase coverage, with a LSB of 5.625 d degrees. the HMc648ALP6e features very low rMS o phase error of 1.2 degrees and extremely low inser- r tion loss variation of ±0.5 dB across all phase states. P this high accuracy phase shifter is control ed with positive control logic of 0/+5V. the HMc648ALP6e is housed in a compact 6x6 mm plastic leadless SMt package and is internal y matched to 50 ohms with no external components.
Electrical Specifications T = +25° C, Vss= -5V, Vdd= +5V , Control Voltage= 0/ +5V, 50 Ohm System A
Parameter Min. typ. Max. units Frequency range 2.9 3.9 GHz Insertion Loss* 5 8 dB Input return Loss* 16 dB output return Loss* 17 dB Phase error* ±5 +10 / -15 deg rMS Phase error 1.2 deg Amplitude Settling time (50% cntl to +/- 0.1dB margin of final rFout) 175 nS Phase Settling time (50% cntl to +/-1 degree margin of final rFout) 125 nS Insertion Loss Variation* ±0.5 dB Input Power for 1 dB compression 31 dBm Input third order Intercept 45 dBm control Voltage current 35 250 µA Bias control current 5 15 mA *Note: Major States Shown Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
