Datasheet S1227 (Hamamatsu) - 5
ManufacturerHamamatsu
DescriptionSi photodiodes. For UV to visible, precision photometry; suppressed IR sensitivity
Pages / Page5 / 5 — Si photodiodes S1227 series Precautions against UV light exposure
File Format / SizePDF / 230 Kb
∙ When UV light irradiation is applied, the product characteristics may degrade. Such examples include degradation of the product’s UV
sensitivity and increase in dark current. This phenomenon varies depending on the irradiation level, irradiation intensity, usage time,
and ambient environment and also varies depending on the product model. Before employing the product, we recommend that you
check the tolerance under the ultraviolet light environment that the product will be used in.
∙ Exposure to UV light may cause the characteristics to degrade due to gas released from the resin bonding the product’s component
materials. As such, we recommend that you avoid applying UV light directly on the resin and apply it on only the inside of the
photosensitive area by using an aperture or the like. Related information
www.hamamatsu.com/sp/ssd/doc_en.html
Precautions
∙ Disclaimer
∙ Metal, ceramic, plastic package products
Technical information
∙ Si photodiode/Application circuit examples Information described in this material is current as of October, 2015.
Product specifications are subject to change without prior notice due to improvements or other reasons. This document has been carefully prepared and the
information contained is believed to be accurate. In rare cases, however, there may be inaccuracies such as text errors. Before using these products, always
contact us for the delivery specification sheet to check the latest specifications.
The product warranty is valid for one year after delivery and is limited to product repair or replacement for defects discovered and reported to us within that
one year period. However, even if within the warranty period we accept absolutely no liability for any loss caused by natural disasters or improper product use.
Copying or reprinting the contents described in this material in whole or in part is prohibited without our prior permission. www.hamamatsu.com
HAMAMATSU PHOTONICS K.K., Solid State Division
1126-1 Ichino-cho, Higashi-ku, Hamamatsu City, 435-8558 Japan, Telephone: (81) 53-434-3311, Fax: (81) 53-434-5184
U.S.A.: Hamamatsu Corporation: 360 Foothill Road, Bridgewater, N.J. 08807, U.S.A., Telephone: (1) 908-231-0960, Fax: (1) 908-231-1218
Germany: Hamamatsu Photonics Deutschland GmbH: Arzbergerstr. 10, D-82211 Herrsching am Ammersee, Germany, Telephone: (49) 8152-375-0, Fax: (49) 8152-265-8
France: Hamamatsu Photonics France S.A.R.L.: 19, Rue du Saule Trapu, Parc du Moulin de Massy, 91882 Massy Cedex, France, Telephone: 33-(1) 69 53 71 00, Fax: 33-(1) 69 53 71 10
United Kingdom: Hamamatsu Photonics UK Limited: 2 Howard Court, 10 Tewin Road, Welwyn Garden City, Hertfordshire AL7 1BW, United Kingdom, Telephone: (44) 1707-294888, Fax: (44) 1707-325777
North Europe: Hamamatsu Photonics Norden AB: Torshamnsgatan 35 16440 Kista, Sweden, Telephone: (46) 8-509-031-00, Fax: (46) 8-509-031-01
Italy: Hamamatsu Photonics Italia S.r.l.: Strada della Moia, 1 int. 6, 20020 Arese (Milano), Italy, Telephone: (39) 02-93581733, Fax: (39) 02-93581741
China: Hamamatsu Photonics (China) Co., Ltd.: B1201, Jiaming Center, No.27 Dongsanhuan Beilu, Chaoyang District, Beijing 100020, China, Telephone: (86) 10-6586-6006, Fax: (86) 10-6586-2866 Cat. No. KSPD1036E07 Oct. 2015 DN 5
