HMC361G8 v00.1111 SMT GaAs HBT MMICDIVIDE-BY-2, 0.01 - 13 GHzTypical ApplicationsFeatures Prescaler for 10 MHz to 13 GHz PLL Applications: ultra Low ssB Phase noise: -148 dBc/Hz t • Point-to-Point / Multi-Point Radios Wide Bandwidth M s • VSAT Radios output Power: 3 dBm • Fiber Optic single Dc supply: +5v s - • Test Equipment 8 Lead Hermetic sMt Package r • Space & Military o t c e t Functional DiagramGeneral Description e the HMc361G8 is a low noise n = 2 static divider in an 8 lead glass/metal surface mount (hermetic) pack- age. this device operates from 10 MHz (with a square s & D wave input) to 13 GHz input frequency with a single r +5v Dc supply. the low additive ssB phase noise of e -148 dBc/Hz at 100 kHz offset helps the user maintain iD good system noise performance. iv y D Electrical Specifications, T = +25° C, 50 Ohm System, Vcc= 5V c A n Parameter conditions Min. typ. Max. units e Maximum input Frequency sine Wave or square Wave input 13 GHz u Minimum input Frequency sine Wave or square Wave input. {1} 0.20 GHz q Minimum input Frequency square Wave {1} {2} 0.01 GHz e Fin = 0.01 to 0.20 GHz (square wave) -10 10 dBm r Fin = 0.20 to 0.5 GHz (sine) 0 10 dBm F Fin = 0.5 to 1 GHz (sine) -10 10 dBm input Power range Fin = 1 to 8 GHz (sine) -15 10 dBm Fin = 8 to 11 GHz (sine) -15 2 Fin = 8 - 13 GHz (sine) -15 0 dBm Fin = 0.20 GHz 4.5 dBm Fin = 6 GHz 3.6 dBm output Power Fin = 9 GHz 1.6 dBm Fin = 13 GHz -2.5 dBm reverse Leakage Both rF outputs terminated 40 dB ssB Phase noise (100 kHz offset) Pin = 0 dBm, Fin = 6 GHz (sine) -148 dBc/Hz output transition time Pin = 0 dBm, Fout = 882 MHz 100 ps supply current (icc) (vcc = +5v) 84 mA 1. Divider will operate down to 0.01 GHz with a square-wave input signal. 2. Square wave input waveform is recommended for operation below 200 MHz. Recommended transitions times are < 100 ps. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m 1 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
