Datasheet HMC705LP4, HMC705LP4E (Analog Devices)
Description6.5 GHz Programmable Divider (N = 1 - 17)
Pages / Page12 / 1 — HMC705LP4 / HMC705LP4E. 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17). …
HMC705LP4 / HMC705LP4E. 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17). Typical Applications. Features. Functional Diagram
Datasheet HMC705LP4, HMC705LP4E Analog Devices
v04.0212
6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17) Typical Applications Features
the HMc705LP4(e) is ideal for: ultra Low ssB Phase noise Floor: t -153 dBc/Hz @ 100 kHz • Satel ite Communication Systems M Programmable Divider (n= 1 - 17) operating s • Point-to-Point Radios up to 6.5 GHz • Military Applications 24 Lead 4X4mm sMt Package: 16mm2 s - • Sonet Clock Generation r • Test Equipment o t c e t
e the HMc705LP4(e) is a low noise GaAs HBt programmable divider in a 4x4 mm leadless surface mount package. the divider can be programmed to s & D divide by any number from n = 1 to n = 17 up to r 6.5 GHz. the HMc705LP4e’s high frequency e operation along with low phase noise floor is very iD useful in high performance fast settling synthesizer iv architectures. the HMc705LP4e may be combined with Hittite’s Phase Frequency Detectors, vcos and PLL ics to create low noise, fast settling phase y D locked loops. c n e u q e r F
Electrical Specifications, T = +25° C, Vcc = Vcc1 = Vcc2 = +5V A
Parameter conditions Min. typ. Max. units Maximum input Frequency sine Wave or square Wave input 6.5 GHz Minimum input Frequency sine Wave or square Wave input 0.1 GHz input Power range Fin = 0.1 to 6.5 GHz* -15 0 10 dBm output Power Divide-by-2 0 dBm ssB Phase noise Fin = 6 GHz, n = 17 -153 dBc/Hz total supply current 190 mA * For sine wave inputs less than 400 MHz input power must be greater than or equal to -5 dBm I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
