Datasheet HMC705LP4, HMC705LP4E (Analog Devices) - 2
Description6.5 GHz Programmable Divider (N = 1 - 17)
Pages / Page12 / 2 — HMC705LP4 / HMC705LP4E. 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17). Input …
HMC705LP4 / HMC705LP4E. 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17). Input Sensitivity Window vs. Temperature,
HMC705LP4 / HMC705LP4E 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17) Input Sensitivity Window vs Temperature,
v04.0212
6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17) Input Sensitivity Window vs. Temperature, Input Sensitivity Window, All States N = 17, T = -40°C to +85°C
20 20 t 10 ) 10 ) m m M (dB (dB R R s E 0 E 0 W W O O P P UT -10 UT -10 s - P P IN IN r -20 -20 o N=1 t 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 c INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) e t e
Output Power, Divide Ratio Output Power, Divide Ratio States 1 through 5 States 6 through 17
1 0 N=6 s & D N=4 N=7 -2 r N=2 N=8 e (dBm) 0 N=9 N=1 -4 N=5 N=10 iD N=11 POWER N=12 -6 iv N=13 -1 N=14 N=3 N=15 OUTPUT OUTPUT POWER (dBm) -8 N=16 y D N=17 c -2 -10 n 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 e INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) u q e
Fundamental Feedthru Power, Pin = 0 dBm
r -15 F N=4 through 17 -25 -35 N=3 -45 OUTPUT LEVEL (dBm) N=2 -55 -65 0 1 2 3 4 5 6 7 INPUT FREQUENCY (GHz) I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
2
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
