Datasheet HMC705LP4, HMC705LP4E (Analog Devices) - 3
Description6.5 GHz Programmable Divider (N = 1 - 17)
Pages / Page12 / 3 — HMC705LP4 / HMC705LP4E. 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17). SSB …
HMC705LP4 / HMC705LP4E. 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17). SSB Phase Noise Performance. 2nd Harmonic, N = 1 through 5
HMC705LP4 / HMC705LP4E 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17) SSB Phase Noise Performance 2nd Harmonic, N = 1 through 5
v04.0212
6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17) SSB Phase Noise Performance SSB Phase Noise Performance
Fin = 6 GHz, N = 2; T = -40°C, +25°C, +85°C Fin = 6 GHz, N = 17; T = -40°C, +25°C, +85°C -110 -110 t M -120 -120 s -40C -130 -130 s - -40C -140 -140 r o -150 -150 t SSB PHASE NOISE (dBc/Hz) SSB PHASE NOISE (dBc/Hz) c -160 -160 e 102 103 104 105 106 107 102 103 104 105 106 107 t OFFSET FREQUENCY (Hz) OFFSET FREQUENCY (Hz) e
Fin = 6 GHz, N = 2; Vcc = 4.75V, 5V, 5.25V Fin = 6 GHz, N = 17; Vcc = 4.75V, 5V, 5.25V s & D -110 -110 r e -120 -120 iD -130 -130 iv -140 -140 y D c -150 -150 SSB PHASE NOISE (dBc/Hz) SSB PHASE NOISE (dBc/Hz) n -160 -160 e 102 103 104 105 106 107 102 103 104 105 106 107 u OFFSET FREQUENCY (Hz) OFFSET FREQUENCY (Hz) q e r F
2nd Harmonic, N = 1 through 5 2nd Harmonic, N = 6 through 17
0 0 N=3 -10 -10 N=5 N=1 (dBm) -20 (dBm) -20 -30 -30 POWER N=4 POWER N=2 -40 -40 OUTPUT OUTPUT -50 -50 -60 -60 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
