Datasheet HMC794LP3E (Analog Devices) - 4
Description2 GHz Low Noise Programmable Divider (N = 1 to 4)
Pages / Page10 / 4 — HMC794LP3E. 2 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Pout …
File Format / SizePDF / 788 Kb
HMC794LP3E. 2 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Pout Divide-by-4 vs. Temperature [1],
HMC794LP3E 2 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Pout Divide-by-4 vs Temperature [1],
HMC794LP3E
v01.0612
2 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Pout Divide-by-4 vs. Temperature [1], Pout Divide-by-4 vs. Supply Voltage [1], (Differential) (Differential)
10 10 5 5 t +25°C 4.75V M (dBm) (dBm) 0 0 +85°C 5.00V s -40°C 5.25V POWER -5 POWER -5 s - r -10 -10 OUTPUT OUTPUT o t -15 -15 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 c INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) e t e
Divide-by-1 Harmonics [1], (Differential) Divide-by-2 Harmonics [1], (Differential)
10 10 s & D 0 H2 0 H3 r -10 H4 H5 e -10 (dBc) -20 (dBc) iD -30 -20 LEVEL LEVEL iv -40 -30 H2 -50 H3 OUTPUT OUTPUT H4 -40 y D -60 H5 c -70 -50 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 n INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) e u q e
Divide-by-3 Harmonics [1], (Differential) Divide-by-4 Harmonics [1], (Differential)
r 10 10 F H2 H2 0 H3 0 H3 H4 H4 -10 H5 -10 H5 (dBc) (dBc) -20 -20 LEVEL LEVEL -30 -30 OUTPUT OUTPUT -40 -40 -50 -50 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) [1] ctrL = 0v, Bias0 = 0v, Pin = +4 dBm I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
4
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
