Datasheet HMC794LP3E (Analog Devices) - 5
Description2 GHz Low Noise Programmable Divider (N = 1 to 4)
Pages / Page10 / 5 — HMC794LP3E. 2 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). …
File Format / SizePDF / 788 Kb
HMC794LP3E. 2 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Divide-by-4 Harmonics [1], (Differential)
HMC794LP3E 2 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Divide-by-4 Harmonics [1], (Differential)
HMC794LP3E
v01.0612
2 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Divide-by-4 Harmonics [1], (Differential) Divide-by-4 Harmonics [2], (Single-Ended)
10 0 t 0 -10 M -20 s -10 (dBc) (dBc) -30 -20 s - LEVEL LEVEL -40 r -30 H2 -50 H2 o H3 OUTPUT H3 OUTPUT -40 H4 H4 t H5 -60 H5 c -50 -70 e 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) t e
Programming Truth Table Absolute Maximum Ratings for Frequency Division Ratios
s & D rF input Power 13 dBm B1 B0 Divide-by r supply voltage (vcc) 5.5v 0 0 1 e control inputs 0 1 2 5.5v iD (B0, B1, ctrL, Bias0, en) 1 0 3 Junction temperature 125 °c iv 1 1 4 continuous Pdiss (t = 85 °c) 1.3W 0 = Logic Low (derate 33 mW/ °c above 85 °c) 1 = Logic High y D thermal resistance 30 °c/W (Junction to ground paddle) c
Digital Control Input Voltages
storage temperature -65 to +125 °c n state B0, B1, ctrL, BiAs1, BiAs0, en e operating temperature -40 to +85 °c Low 0 to 0.4v u esD sensitivity (HBM) class 1A High 3v to 5v q e r F eLectrostAtic sensitive Device
Typical Supply Current vs. Vcc
oBserve HAnDLinG PrecAutions vcc (v) icc (mA) 4.75 105* 5.00 115* 5.25 125* note: HMc794LP3e will work over full voltage range above. * For ctrL = 0v, Bias0 = 0v [1] ctrL = 5v, Bias0 = 0v, Pin = +4 dBm [2] ctrL = 0v, Bias0 = 0v, Pin = +4 dBm I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
