Datasheet HMC437MS8G, 437MS8GE (Analog Devices)
DescriptionSMT 4 SMT GaAs HBT MMIC DIVIDE-BY-3, DC - 7 GHz
Pages / Page6 / 1 — HMC437MS8G / 437MS8GE. SMT GaAs HBT MMIC. DIVIDE-BY-3, DC - 7 GHz. …
File Format / SizePDF / 362 Kb
HMC437MS8G / 437MS8GE. SMT GaAs HBT MMIC. DIVIDE-BY-3, DC - 7 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC437MS8G, 437MS8GE Analog Devices
v05.1211
SMT GaAs HBT MMIC DIVIDE-BY-3, DC - 7 GHz Typical Applications Features
4 Prescaler for Dc to c Band PLL Applications: ssB Phase noise: -153 dBc/Hz @100KHz 4 • UNII, Point-to-Point & VSAT Radios Wide Bandwidth t • 802.11a & HiperLAN WLAN output Power: -1 dBm • Fiber Optic single Dc supply: +5v @ 69 mA t M M s • Cel ular / 3G Infrastructure Ms8G sMt Package s s - s - r r o o t t c
c e the HMc437Ms8G & HMc437Ms8Ge are low noise e t Divide-by-3 static Dividers utilizing inGaP GaAs t e e HBt technology in low cost 8 lead surface mount plastic packages. this device operates from Dc (with a square wave input) to 7 GHz input frequency s & D from a single +5v Dc supply. the low additive ssB s & D r phase noise of -153 dBc/Hz at 100 kHz offset helps r e the user maintain good system noise performance. e iD iD iv iv y D y D c c n n e e u u q
Electrical Specifications, T = +25° C, 50 Ohm System, Vcc= 5V A
q e Parameter conditions Min. typ. Max. units e r Maximum input Frequency 7.0 7.5 GHz r F Minimum input Frequency sine Wave input [1] 0.1 GHz F input Power range Fin= 1 to 6 GHz -12 +12 dBm Fin= 6 to 7 GHz -10 +10 dBm output Power -4 -1 dBm reverse Leakage Both rF outputs terminated -50 dBm ssB Phase noise (100 kHz offset) Pin= 0 dBm, Fin= 6 GHz -153 dBc/Hz output transition time Pin= 0 dBm, Fout= 882 MHz 100 ps supply current (icc) 69 mA 1. Divider will operate down to DC for square-wave input signal. Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
4 - 1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
