Datasheet HMC394LP4, 394LP4E (Analog Devices) - 2
DescriptionGaAs HBT PROGRAMMABLE 5-BIT COUNTER, DC - 2.2 GHz
Pages / Page10 / 2 — HMC394LP4 / 394LP4E. GaAs HBT PROGRAMMABLE. 5-BIT COUNTER, DC - 2.2 GHz. …
File Format / SizePDF / 591 Kb
HMC394LP4 / 394LP4E. GaAs HBT PROGRAMMABLE. 5-BIT COUNTER, DC - 2.2 GHz. Input Sensitivity Window, 5 major
HMC394LP4 / 394LP4E GaAs HBT PROGRAMMABLE 5-BIT COUNTER, DC - 2.2 GHz Input Sensitivity Window, 5 major
HMC394LP4 / 394LP4E
v09.0114
GaAs HBT PROGRAMMABLE 5-BIT COUNTER, DC - 2.2 GHz Input Sensitivity Window, 5 major Input Sensitivity Window vs. Divide Ratio States, T= 25 °C Temperature, N= 16, T= -40 °C to +85 °C
4 20 20 4 10 10 ) m m t dB ( 0 (dB R 0 R t M E
Recommended
E W W
Operating Window
O M s PO -10 P -10 T UT s U P P s - IN IN -20 -20 s - r -30 -30 r o 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 o t INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) t c c e e t
Output Power, 5 Major Divide SSB Phase Noise Performance,
t e
Ratio States, T= 25 °C Fin= 1 GHz, N= 4, T= 25 °C
e 10 -60 N=2 N=4 -70 5 s & D -80 -90 0 s & D r N=8 -100 r e -5 -110 e iD N=16 -120 -10 iD iv -130 Output Power (dBm) N=32 -140 iv -15 SSB PHASE NOISE (dBc/Hz) -150 y D -20 -160 y D c 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 2.2 2.4 102 103 104 105 106 107 INPUT FREQUENCY (GHz) OFFSET FREQUENCY (Hz) c n n e e u
Fundamental Feedthru Power,
u q
Pin= 0 dBm, T= 25 °C Typical Supply Current vs. Vcc
q e 0 Vcc (V) Icc (mA) e r 4.75 176 r F -10 5.0 194 F 5.25 210 -20 Note: Divider will operate over full voltage range shown above. -30 N=2 N=4 OUTPUT LEVEL (dBm) -40 N=8 N=16 N=32 -50 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 2.2 2.4 INPUT FREQUENCY (GHz) Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4 - 2
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
