Datasheet HMC365G8 (Analog Devices)
DescriptionSMT GaAs HBT MMIC DIVIDE-BY-4, DC - 13 GHz
Pages / Page6 / 1 — HMC365G8. SMT GaAs HBT MMIC. DIVIDE-BY-4, DC - 13 GHz. Typical …
File Format / SizePDF / 353 Kb
HMC365G8. SMT GaAs HBT MMIC. DIVIDE-BY-4, DC - 13 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC365G8 Analog Devices
HMC365G8
v02.0410
SMT GaAs HBT MMIC DIVIDE-BY-4, DC - 13 GHz Typical Applications Features
4 Prescaler for DC to Ku Band PLL Applications: Ultra Low SSB Phase Noise: -151 dBc/Hz • Point-to-Point / Multi-Point Radios Wide Bandwidth • VSAT Radios Output Power: 7 dBm T • Fiber Optic Single DC Supply: +5V • Test Equipment 8 Lead Hermetic SMT Package • Space & Military S - SM R O T C
E T The HMC365G8 is a low noise Divide-by-4 Static E Divider with InGaP GaAs HBT technology in an 8 lead glass/metal (hermetic) surface mount hermetic package. This device operates from DC (with a square & D wave input) to 13 GHz input frequency with a single S +5V DC supply. The low additive SSB phase noise R of -151 dBc/Hz at 100 kHz offset helps the user E maintain good system noise performance. ID IV Y D NC E U Q
Electrical Specifi cations, T = +25° C, 50 Ohm System, Vcc = 5V A
E Parameter Conditions Min. Typ. Max. Units R F Maximum Input Frequency 13 14 GHz Minimum Input Frequency Sine Wave Input. [1] 0.2 0.5 GHz Input Power Range Fin = 1 to 11 GHz -15 >-20 +10 dBm Fin = 11 to 12 GHz -10 >-15 +5 dBm Fin = 12 to 13 GHz -5 >-8 0 dBm Output Power Fin = 13 GHz 3 7 dBm Reverse Leakage Both RF Outputs Terminated 45 dB SSB Phase Noise (100 kHz offset) Pin = 0 dBm, Fin = 6 GHz -151 dBc/Hz Output Transition Time Pin = 0 dBm, Fout = 882 MHz 100 ps Supply Current (Icc) 120 mA 1. Divider will operate down to DC for square-wave input signal. Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
4 - 1
Phone: 978-250-3343 Fax: 978-250-3373 O P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
