LT1725 UUUPI FU CTIO S ENDLY (Pin 13): Pin for external programming resistor to VCC (Pin 15): Supply voltage for the LT1725. Bypass this set enable delay time. See Applications Information for pin to ground with 1µF or more. details. GATE (Pin 16): This is the gate drive to the external power tON (Pin 14): Pin for external programming resistor to set MOSFET switch and has large dynamic currents flowing switch minimum on time. See Applications Information through it. Keep the trace to the MOSFET as short as for details. possible to minimize electromagnetic radiation and volt- age spikes. A series resistance of 5Ω or more may help to dampen ringing in less than ideal layouts. WBLOCK DIAGRA VCC 3VOUT UVLO BIAS 3V REG (INTERNAL) t MINENAB ENDLY ON OSCAP GATE MOSFET OSC LOGIC DRIVER PGND ISENSE COMP IAMP SGND FB LOAD FDBK SOFT-START COMPENSATION 1725 BD VC SFST ROCMP RCMPC 1725fa 7
