Datasheet ATmega103, ATmega103L (Atmel) - 3
ManufacturerAtmel
Description8-bit AVR Microcontroller with 128K Bytes In-System Programmable Flash
Pages / Page141 / 3 — ATmega103(L). Description
ATmega103(L) Description
The ATmega103(L) is a low-power, CMOS, 8-bit microcontroller based on the AVR RISC architecture. By executing powerful instructions in a single clock cycle, the ATmega103(L) achieves throughputs approaching 1 MIPS per MHz, allowing the sys- tem designer to optimize power consumption versus processing speed. The AVR core is based on an enhanced RISC architecture that combines a rich instruc- tion set with 32 general purpose working registers. All the 32 registers are directly connected to the Arithmetic Logic Unit (ALU), allowing two independent registers to be accessed in one single instruction executed in one clock cycle. The resulting architec- ture is more code efficient while achieving throughputs up to ten times faster than conventional CISC microcontrollers. The ATmega103(L) provides the following features: 128K bytes of In-System Program- mable Flash, 4K bytes EEPROM, 4K bytes SRAM, 32 general purpose I/O lines, 8 input lines, 8 output lines, 32 general purpose working registers, Real Time Counter (RTC), 4 flexible Timer/Counters with compare modes and PWM, UART, programmable Watch- dog Timer with internal Oscillator, an SPI serial port and 3 software-selectable power saving modes. The Idle mode stops the CPU while allowing the SRAM, Timer/Counters, SPI port and interrupt system to continue functioning. The Power-down mode saves the register contents but freezes the Oscillator, disabling all other chip functions until the next Interrupt or Hardware Reset. In Power-save mode, the Timer Oscillator continues to run, allowing the user to maintain a timer base while the rest of the device is sleeping. The device is manufactured using Atmel’s high-density nonvolatile memory technology. The On-chip ISP Flash allows the Program memory to be reprogrammed In-System through a serial interface or by a conventional nonvolatile memory programmer. By combining an 8-bit RISC CPU with a large array of ISP Flash on a monolithic chip, the Atmel ATmega103(L) is a powerful microcontroller that provides a highly flexible and cost-effective solution to many embedded control applications. The ATmega103(L) AVR is supported with a full suite of program and system develop- ment tools including: C compilers, macro assemblers, program debugger/simulators, In- Circuit Emulators and evaluation kits.
3
0945I–AVR–02/07 Document Outline Features Pin Configuration Description Block Diagram Pin Descriptions VCC GND Port A (PA7..PA0) Port B (PB7..PB0) Port C (PC7..PC0) Port D (PD7..PD0) Port E (PE7..PE0) Port F (PF7..PF0) RESET XTAL1 XTAL2 TOSC1 TOSC2 WR RD ALE AVCC AREF AGND PEN Clock Options Crystal Oscillator External Clock Timer Oscillator Architectural Overview General Purpose Register File X-register, Y-register and Z- register ALU - Arithmetic Logic Unit ISP Flash Program Memory SRAM Data Memory Program and Data Addressing Modes Register Direct, Single Register Rd Register Direct, Two Registers Rd and Rr I/O Direct Data Direct Data Indirect with Displacement Data Indirect Data Indirect with Pre- decrement Data Indirect with Post- increment Constant Addressing Using the LPM and ELPM Instructions Direct Program Address, JMP and CALL Indirect Program Addressing, IJMP and ICALL Relative Program Addressing, RJMP and RCALL EEPROM Data Memory Memory Access Times and Instruction Execution Timing I/O Memory Status Register - SREG Stack Pointer - SP RAM Page Z Select Register - RAMPZ MCU Control Register - MCUCR XTAL Divide Control Register - XDIV Reset and Interrupt Handling Reset Sources Power-on Reset External Reset Watchdog Reset MCU Status Register - MCUSR Interrupt Handling External Interrupt Mask Register - EIMSK External Interrupt Flag Register - EIFR External Interrupt Control Register - EICR Timer/Counter Interrupt Mask Register - TIMSK Timer/Counter Interrupt Flag Register - TIFR Interrupt Response Time Sleep Modes Idle Mode Power-down Mode Power-save Mode Timer/Counters Timer/Counter Prescalers 8-bit Timer/Counters T/C0 and T/C2 Timer/Counter0 Control Register - TCCR0 Timer/Counter2 Control Register - TCCR2 Timer/Counter0 - TCNT0 Timer/Counter2 - TCNT2 Timer/Counter0 Output Compare Register - OCR0 Timer/Counter2 Output Compare Register - OCR2 Timer/Counters 0 and 2 in PWM Mode Asynchronous Status Register - ASSR Asynchronous Operation of Timer/Counter0 16-bit Timer/Counter1 Timer/Counter1 Control Register A - TCCR1A Timer/Counter1 Control Register B - TCCR1B Timer/Counter1 - TCNT1H and TCNT1L Timer/Counter1 Output Compare Register - OCR1AH and OCR1AL Timer/Counter1 Output Compare Register - OCR1BH and OCR1BL Timer/Counter1 Input Capture Register - ICR1H and ICR1L Timer/Counter1 in PWM Mode Watchdog Timer Watchdog Timer Control Register - WDTCR EEPROM Read/Write Access EEPROM Address Register - EEARH, EEARL EEPROM Data Register - EEDR EEPROM Control Register - EECR Prevent EEPROM Corruption Serial Peripheral Interface - SPI SS Pin Functionality Data Modes SPI Control Register - SPCR SPI Status Register - SPSR SPI Data Register - SPDR UART Data Transmission Data Reception UART Control UART I/O Data Register - UDR UART Status Register - USR UART Control Register - UCR Baud Rate Generator UART Baud Rate Register - UBRR Analog Comparator Analog Comparator Control and Status Register - ACSR Analog-to-Digital Converter Feature list: Operation Prescaling ADC Noise Canceler Function ADC Multiplexer Select Register - ADMUX ADC Control and Status Register - ADCSR ADC Data Register - ADCL and ADCH ADC Noise Canceling Techniques ADC DC Characteristics Interface to External SRAM I/O Ports Port A Port A Data Register - PORTA Port A Data Direction Register - DDRA Port A Input Pins Address - PINA Port A as General Digital I/O Port A Schematics Port B Port B Data Register - PORTB Port B Data Direction Register - DDRB Port B Input Pins Address - PINB Port B as General Digital I/O Alternate Functions of Port B Port B Schematics Port C The Port C Data Register - PORTC Port C Schematics Port D Port D Data Register - PORTD Port D Data Direction Register - DDRD Port D Input Pins Address - PIND Port D as General Digital I/O Alternate Functions of Port D Port D Schematics Port E Port E Data Register - PORTE Port E Data Direction Register - DDRE Port E Input Pins Address - PINE Port E as General Digital I/O Alternate Functions of Port E Port E Schematics Port F Port F Input Pins Address - PINF Memory Programming Program and Data Memory Lock Bits Fuse Bits Signature Bytes Programming the Flash and EEPROM Parallel Programming Signal Names Enter Programming Mode Chip Erase Programming the Flash Programming the EEPROM Reading the Flash Reading the EEPROM Programming the Fuse Bits Programming the Lock Bits Reading the Fuse and Lock Bits Reading the Signature Bytes Parallel Programming Characteristics Serial Downloading Serial Programming Algorithm Data Polling for the EEPROM Electrical Characteristics Absolute Maximum Ratings* DC Characteristics External Data Memory Timing External Clock Drive Waveforms Typical Characteristics Register Summary Instruction Set Summary Ordering Information Packaging Information 64A Table of Contents
