Datasheet ATtiny22, ATtiny22L - Preliminary (Atmel) - 2
ManufacturerAtmel
Description8-bit AVR Microcontroller with 2K Bytes of In-System Programmable Flash
Pages / Page59 / 2 — Block Diagram. Figure 1. ATtiny22/22L
Block Diagram Figure 1 ATtiny22/22L
The AVR core combines a rich instruction set with 32 general purpose working registers. All the 32 registers are directly connected to the Arithmetic Logic Unit (ALU), allowing two independent registers to be accessed in one single instruction executed in one clock cycle. The resulting architecture is more code efficient while achieving throughputs up to ten times faster than conventional CISC microcontrollers.
Block Diagram Figure 1.
The ATtiny22/L Block Diagram VCC 8-BIT DATA BUS INTERNAL OSCILLATOR GND PROGRAM STACK WATCHDOG TIMING AND RESET COUNTER POINTER TIMER CONTROL PROGRAM MCU CONTROL SRAM FLASH REGISTER INSTRUCTION GENERAL TIMER/ REGISTER PURPOSE COUNTER REGISTERS X INSTRUCTION Y INTERRUPT DECODER Z UNIT CONTROL ALU EEPROM LINES STATUS REGISTER PROGRAMMING SPI LOGIC DATA REGISTER DATA DIR. PORTB REG. PORTB PORTB DRIVERS PB0 - PB4
2 ATtiny22/22L
Document Outline Features Description Block Diagram Pin Descriptions ATtiny22/L VCC GND Port B (PB4..PB0) RESET CLOCK Clock Options External Clock Architectural Overview General Purpose Register File X-Register, Y-Register, and Z-Register ALU - Arithmetic Logic Unit In-System Programmable Flash Program Memory EEPROM Data Memory SRAM Data Memory Program and Data Addressing Modes Register Direct, Single Register Rd Register Direct, Two Registers Rd and Rr I/O Direct Data Direct Data Indirect with Displacement Data Indirect Data Indirect With Pre-Decrement Data Indirect With Post-Increment Constant Addressing Using the LPM Instruction Indirect Program Addressing, IJMP and ICALL Relative Program Addressing, RJMP and RCALL Memory Access and Instruction Execution Timing I/O Memory Status Register - SREG Stack Pointer - SPL Reset and Interrupt Handling Reset Sources Power-On Reset External Reset Watchdog Reset MCU Status Register - MCUSR Interrupt Handling General Interrupt Mask Register - GIMSK General Interrupt Flag Register - GIFR Timer/Counter Interrupt Mask Register - TIMSK Timer/Counter Interrupt FLAG Register - TIFR External Interrupt Interrupt Response Time MCU Control Register - MCUCR Sleep Modes Idle Mode Power Down Mode Timer/Counter Timer/Counter Prescaler 8-Bit Timer/Counter0 Timer/Counter0 Control Register - TCCR0 Timer Counter 0 - TCNT0 Watchdog Timer Watchdog Timer Control Register - WDTCR EEPROM Read/Write Access EEPROM Address Register - EEAR EEPROM Data Register - EEDR EEPROM Control Register - EECR Prevent EEPROM Corruption I/O Port B Port B Data Register - PORTB Port B Data Direction Register - DDRB Port B Input Pins Address - PINB General Digital I/O Alternate Functions of Port B CLOCK - Port B, Bit 3 SCK/T0 - Port B, Bit 2 MISO - Port B, Bit 1 MOSI - Port B, Bit 0 Memory Programming Program and Data Memory Lock Bits Fuse Bits Signature Bytes Programming the Flash and EEPROM High-Voltage Serial Programming High-Voltage Serial Programming Algorithm High-Voltage Serial Programming Characteristics Low-Voltage Serial Downloading Low-Voltage Serial Programming Algorithm Data Polling EEPROM Data Polling Flash Low-Voltage Serial Programming Characteristics Electrical Characteristics Absolute Maximum Ratings* DC Characteristics External Clock Drive Waveforms External Clock Drive Typical characteristics Register Summary Instruction Set Summary (Continued) Ordering Information
