Datasheet ADUM5010 (Analog Devices)
Description | Integrated DC-to-DC Converter |
Pages / Page | 16 / 1 — Integrated DC-to-DC Converter. Data Sheet. ADuM5010. FEATURES. FUNCTIONAL … |
Revision | A |
File Format / Size | PDF / 480 Kb |
Integrated DC-to-DC Converter. Data Sheet. ADuM5010. FEATURES. FUNCTIONAL BLOCK DIAGRAM. iso
![Datasheet ADUM5010 Analog Devices, Revision: A](https://www.rlocman.ru/datasheet/img.php?di=149469)
link to page 1 link to page 1
Integrated DC-to-DC Converter Data Sheet ADuM5010 FEATURES FUNCTIONAL BLOCK DIAGRAM iso Power integrated, isolated dc-to-dc converter NC 1 ADuM5010 20 NC Regulated 3.15 V to 5.25 V output Up to 150 mW output power GNDP 2 19 GNDISO 20-lead SSOP package with 5.3 mm creepage NC 3 18 NC High temperature operation: 105°C NC 4 17 NC High common-mode transient immunity: >25 kV/µs GNDP 5 16 GNDISO Safety and regulatory approvals GNDP 6 15 GNDISO UL recognition (pending) NC 7 14 NC 2500 V rms for 1 minute per UL 1577 PDIS 8 PCS 13 V CSA Component Acceptance Notice #5A (pending) SEL V VDE certificate of conformity (pending) DDP 9 1.25V 12 VISO DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 GND
001
P 10 OSC RECT REG 11 GNDISO V
10978-
IORM = 560 V peak
Figure 1.
APPLICATIONS Power supply start-up bias and gate drives Isolated sensor interfaces Industrial PLCs GENERAL DESCRIPTION
The ADuM50101 is an integrated, isolated dc-to-dc converter.
Table 1. Power Levels
Based on the Analog Devices, Inc., iCoupler® technology, the
Input Voltage (V) Output Voltage (V) Output Power (mW)
dc-to-dc converter provides regulated, isolated power, adjustable 5 5 150 between 3.15 V and 5.25 V. Input supply voltages can range 5 3.3 100 from slightly below the required output to significantly higher. 3.3 3.3 66 Popular combinations and their associated power levels are shown in Table 1. The iCoupler chip-scale transformer technology is used for isolated logic signals and for the magnetic components of the dc-to-dc converter. The result is a small form factor, total isolation solution. isoPower uses high frequency switching elements to transfer power through its transformer. Special care must be taken during printed circuit board (PCB) layout to meet emissions standards. See the AN-0971 Application Note for board layout recommendations. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 6,903,578; and 7,075,329. Other patents are pending.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2012–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Package Characteristics Regulatory Approvals Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Truth Table Typical Performance Characteristics Applications Information PCB Layout Thermal Analysis EMI Considerations Insulation Lifetime Outline Dimensions Ordering Guide
