Datasheet ADuM6200, ADuM6201, ADuM6202 (Analog Devices)
DescriptionDual-Channel, 5 kV Isolators with Integrated DC-to-DC Converter
Pages / Page28 / 1 — Dual-Channel, 5 kV Isolators with. Integrated DC-to-DC Converter. Data …
RevisionC
File Format / SizePDF / 576 Kb
Dual-Channel, 5 kV Isolators with. Integrated DC-to-DC Converter. Data Sheet. ADuM6200/. ADuM6201/. ADuM6202. FEATURES
Datasheet ADuM6200, ADuM6201, ADuM6202 Analog Devices, Revision: C
link to page 1 link to page 25 link to page 1
Dual-Channel, 5 kV Isolators with Integrated DC-to-DC Converter Data Sheet ADuM6200/ ADuM6201/ ADuM6202 FEATURES FUNCTIONAL BLOCK DIAGRAMS iso Power integrated, isolated dc-to-dc converter V OSCILLATOR RECTIFIER REGULATOR Regulated 5 V or 3.3 V output 1 16 DD1 VISO Up to 400 mW output power GND 2 15 1 GNDISO Dual dc-to-25 Mbps (NRZ) signal isolation channels V 3 14 IA/VOA VIA/VOA 16-lead SOIC wide body package version 2-CHANNEL i COUPLER CORE V 4 13 V 16-lead SOIC wide body enhanced creepage version IB/VOB IB/VOB High temperature operation: 105°C maximum RC 5 12 IN NC Safety and regulatory approvals RC 6 11 SEL VSEL ADuM6200/ UL recognition V 7 ADuM6201/ 10 E1/NC VE2/NC 5000 V rms for 1 minute per UL 1577
1
ADuM6202
00 5-
CSA Component Acceptance Notice #5A GND 8 9 1 GNDISO
77 08
IEC 60601-1: 250 V rms, 8 mm package (RI-16-1) NC = NO CONNECT IEC 60950-1: 400 V rms, 8 mm package (RI-16-1)
Figure 1.
VDE certificate of conformity (RW-16) IEC 60747-5-2 (VDE 0884 Part 2):2003-01 V V V IORM = 846 V peak IA OA 3 14 VDE certificate of conformity, 8 mm package (RI-16-1) ADuM6200
2
DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 VIB VOB
00
4 13
5- 77
V IORM = 846 V peak
08 Figure 2. ADuM6200
APPLICATIONS RS-232/RS-422/RS-485 transceivers V V Industrial field bus isolation IA OA 3 14 Isolated sensor interfaces ADuM6201 V
3
OB VIB Industrial PLCs
00
4 13
5- 77 08
GENERAL DESCRIPTION
Figure 3. ADuM6201 The ADuM6200/ADuM6201/ADuM62021 are dual-channel digital isolators with isoPower®, an integrated, isolated dc-to-dc
V V
converter. Based on the Analog Devices, Inc., iCoupler® technology,
OA IA 3 14
the dc-to-dc converter provides up to 400 mW of regulated, iso-
ADuM6202 V
4
OB VIB
lated power at either 5.0 V or 3.3 V from a 5.0 V input supply, or 00
4 13
5- 77 at 3.3 V from a 3.3 V supply at the power levels shown in Table 1. 08 Figure 4. ADuM6202 These devices eliminate the need for a separate, isolated dc-to-dc converter in low power, isolated designs. The iCoupler chip scale transformer technology is used to isolate the logic signals and for
Table 1. Power Levels
the magnetic components of the dc-to-dc converter. The result
Input Voltage (V) Output Voltage (V) Output Power (mW)
is a small form factor, total isolation solution. 5.0 5.0 400 The ADuM6200/ADuM6201/ADuM6202 isolators provide two 5.0 3.3 330 independent isolation channels in a variety of channel configura- 3.3 3.3 132 tions and data rates (see the Ordering Guide for more information). isoPower uses high frequency switching elements to transfer power through its transformer. Special care must be taken during printed circuit board (PCB) layout to meet emissions standards. See the AN-0971 Application Note for board layout recommendations. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 6,903,578; and 7,075,329; other patents are pending.
Rev. C Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices f or its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2010–2012 Analog Devices, Inc. Al l rights reserved.
Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Package Characteristics Regulatory Information Insulation and Safety-Related Specifications Insulation Characteristics IEC 60747-5-2 (VDE 0884 Part 2):2003-01 and DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 Thermal Derating Curve Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table Typical Performance Characteristics Terminology Applications Information PCB Layout Start-Up Behavior EMI Considerations Propagation Delay Parameters DC Correctness and Magnetic Field Immunity Power Consumption Current-Limit and Thermal Overload Protection Power Considerations Thermal Analysis Increasing Available Power Insulation Lifetime Outline Dimensions Ordering Guide
