Datasheet ADuM6200, ADuM6201, ADuM6202 (Analog Devices) - 5
DescriptionDual-Channel, 5 kV Isolators with Integrated DC-to-DC Converter
Pages / Page28 / 5 — Data Sheet. ADuM6200/ADuM6201/ADuM6202. Table 7. DC-to-DC Converter …
RevisionC
File Format / SizePDF / 576 Kb
Data Sheet. ADuM6200/ADuM6201/ADuM6202. Table 7. DC-to-DC Converter Dynamic Specifications. 1 Mbps—A or C Grade
Data Sheet ADuM6200/ADuM6201/ADuM6202 Table 7 DC-to-DC Converter Dynamic Specifications 1 Mbps—A or C Grade
link to page 5 link to page 5 link to page 5
Data Sheet ADuM6200/ADuM6201/ADuM6202 Table 7. DC-to-DC Converter Dynamic Specifications 1 Mbps—A or C Grade 25 Mbps—C Grade Test Conditions/ Parameter Symbol Min Typ Max Min Typ Max Unit Comments
SUPPLY CURRENT Input I DD1(D) ADuM6200 6 23 mA No V load ISO ADuM6201 7 25 mA No V load ISO ADuM6202 8 27 mA No V load ISO Available to Load I ISO(LOAD) ADuM6200 40 36 mA ADuM6201 40 35 mA ADuM6202 40 34 mA
Table 8. Switching Specifications A Grade C Grade Test Conditions/ Parameter Symbol Min Typ Max Min Typ Max Unit Comments
SWITCHING SPECIFICATIONS Data Rate 1 25 Mbps Within PWD limit Propagation Delay t , t 60 100 45 65 ns 50% input to 50% output PHL PLH Pulse Width Distortion PWD 40 6 ns |t − t | PLH PHL Change vs. Temperature 5 ps/°C Pulse Width PW 1000 40 ns Within PWD limit Propagation Delay Skew t 50 45 ns Between any two units PSK Channel Matching Codirectional1 t 50 6 ns PSKCD Opposing Directional2 t 50 15 ns PSKOD 1 Codirectional channel matching is the absolute value of the difference in propagation delays between any two channels with inputs on the same side of the isolation 7 barrier. 2 Opposing directional channel matching is the absolute value of the difference in propagation delays between any two channels with inputs on opposite sides of the isolation barrier.
Table 9. Input and Output Characteristics Test Conditions/ Parameter Symbol Min Typ Max Unit Comments
DC SPECIFICATIONS Logic High Input Threshold V 0.7 × V or 0.7 × V V IH ISO DD1 Logic Low Input Threshold V 0.3 × V or 0.3 × V V IL ISO DD1 Logic High Output Voltages V V − 0.3 or V − 0.3 3.3 V I = −20 µA, V = V OH DD1 ISO Ox Ix IxH V − 0.5 or V − 0.5 3.1 V I = −4 mA, V = V DD1 ISO Ox Ix IxH Logic Low Output Voltages V 0.0 0.1 V I = 20 µA, V = V OL Ox Ix IxL 0.0 0.4 V I = 4 mA, V = V Ox Ix IxL Undervoltage Lockout UVLO V , V supplies DD1 ISO Positive-Going Threshold V 2.7 V UV+ Negative-Going Threshold V 2.4 V UV− Hysteresis V 0.3 V UVH Input Currents per Channel I −20 +0.01 +20 µA 0 V ≤ V ≤ V I Ix DD1 AC SPECIFICATIONS Output Rise/Fall Time t /t 2.5 ns 10% to 90% R F Common-Mode Transient |CM| 25 35 kV/µs V = V or V , V = 1000 V, Ix DD1 ISO CM Immunity1 transient magnitude = 800 V Refresh Rate f 1.0 Mbps r 1 |CM| is the maximum common-mode voltage slew rate that can be sustained while maintaining VO > 0.7 × VDD1 or 0.7 × VISO for a high input or VO < 0.3 × VDD1 or 0.3 × VISO for a low input. The common-mode voltage slew rates apply to both rising and falling common-mode voltage edges. Rev. C | Page 5 of 28 Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Package Characteristics Regulatory Information Insulation and Safety-Related Specifications Insulation Characteristics IEC 60747-5-2 (VDE 0884 Part 2):2003-01 and DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 Thermal Derating Curve Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table Typical Performance Characteristics Terminology Applications Information PCB Layout Start-Up Behavior EMI Considerations Propagation Delay Parameters DC Correctness and Magnetic Field Immunity Power Consumption Current-Limit and Thermal Overload Protection Power Considerations Thermal Analysis Increasing Available Power Insulation Lifetime Outline Dimensions Ordering Guide
