Datasheet ADUM5000 (Analog Devices)
Description2.5 kV, Isolated DC-to-DC Converter
Pages / Page15 / 1 — 2.5 kV, Isolated DC-to-DC Converter. Data Sheet. ADuM5000W. FEATURES. …
RevisionA
File Format / SizePDF / 333 Kb
2.5 kV, Isolated DC-to-DC Converter. Data Sheet. ADuM5000W. FEATURES. FUNCTIONAL BLOCK DIAGRAM. iso
Datasheet ADUM5000 Analog Devices, Revision: A
link to page 1
2.5 kV, Isolated DC-to-DC Converter Data Sheet ADuM5000W FEATURES FUNCTIONAL BLOCK DIAGRAM iso Power integrated, isolated dc-to-dc converter VDD1 1 OSC RECT REG 16 VISO Regulated 3.3 V or 5 V output Up to 400 mW output power GND1 2 15 GNDISO 16-lead SOIC package with 7.6 mm creepage NC 3 14 NC High temperature operation: 105°C maximum Thermal overload protection RCIN 4 13 VSEL Safety and regulatory approvals RCOUT 5 12 NC UL recognition 2500 V rms for 1 minute per UL 1577 RCSEL 6 11 NC CSA Component Acceptance Notice #5A VDD1 7 10 VISO VDE certificate of conformity (pending)
001
IEC 60747-5-2 (VDE 0884, Part 2) GND1 8 9 GND ADuM5000W ISO
10971-
VIORM = 560 V peak
Figure 1.
Qualified for automotive applications APPLICATIONS Automotive battery monitor RS-232/RS-422/RS-485 transceivers Power supply startups and gate drives Isolated sensor interfaces GENERAL DESCRIPTION
The ADuM5000W1 is an isolated dc-to-dc converter based on isoPower uses high frequency switching elements to transfer power the Analog Devices, Inc., iCoupler® technology. The dc-to-dc through its transformer. Special care must be taken during printed converter in this device provides regulated, isolated power in circuit board (PCB) layout to meet emissions standards. See the several combinations of input and output voltages as listed in AN-0971 Application Note for board layout recommendations. Table 1.
Table 1.
The Analog Devices chip scale transformer, iCoupler technology,
Input Voltage (V) Output Voltage (V) Output Power (mW)
transfers isolated power in this dc-to-dc converter with up to 5 5 400 33% efficiency. The result is a small form factor, total isolation 5 3.3 330 solution. 3.3 3.3 132 Higher output power levels are obtained by using the ADuM5000W to augment the power output of ADuM5401, ADuM5402, ADuM5403, ADuM5404, ADuM520x, and other ADuM5000W iCouplers with isoPower®. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 6,903,578; and 7,075,329.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2012–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/5 V SECONDARY ISOLATED SUPPLY ELECTRICAL CHARACTERISTICS—3.3 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS IEC 60747-5-2 (VDE 0884, PART 2):2003-01 INSULATION CHARACTERISTICS Thermal Derating Curve RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION PCB LAYOUT START-UP BEHAVIOR EMI CONSIDERATIONS THERMAL ANALYSIS CURRENT LIMIT AND THERMAL OVERLOAD PROTECTION POWER CONSIDERATIONS INCREASING AVAILABLE POWER INSULATION LIFETIME OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
