Datasheet LT6654 (Analog Devices) - 4
DescriptionPrecision Wide Supply High Output Drive Low Noise Reference
Pages / Page22 / 4 — available opTions. OUTPUT VOLTAGE. INITIAL ACCURACY. TEMPERATURE …
available opTions. OUTPUT VOLTAGE. INITIAL ACCURACY. TEMPERATURE COEFFICIENT. ORDER PART NUMBER**. SPECIFIED TEMPERATURE RANGE
available opTions OUTPUT VOLTAGE INITIAL ACCURACY TEMPERATURE COEFFICIENT ORDER PART NUMBER** SPECIFIED TEMPERATURE RANGE
LT6654
LT6654
1.25V 0.05% 10ppm/°C LT6654AIS6-1.25 –40°C to 85°C 0.1% 20ppm/°C LT6654BIS6-1.25 –40°C to 85°C 0.05% 10ppm/°C LT6654AHS6-1.25 –40°C to 125°C 0.1% 20ppm/°C LT6654BHS6-1.25 –40°C to 125°C 0.05% 10ppm/°C LT6654AMPS6-1.25 –55°C to 125°C 0.1% 20ppm/°C LT6654BMPS6-1.25 –55°C to 125°C 2.048V 0.05% 10ppm/°C LT6654AIS6-2.048 –40°C to 85°C 0.1% 20ppm/°C LT6654BIS6-2.048 –40°C to 85°C 0.05% 10ppm/°C LT6654AHS6-2.048 –40°C to 125°C 0.05% 10ppm/°C LT6654AHLS8-2.048 –40°C to 125°C 0.1% 20ppm/°C LT6654BHS6-2.048 –40°C to 125°C 0.1% 20ppm/°C LT6654BHLS8-2.048 –40°C to 125°C 0.05% 10ppm/°C LT6654AMPS6-2.048 –55°C to 125°C 0.1% 20ppm/°C LT6654BMPS6-2.048 –55°C to 125°C 2.5V 0.05% 10ppm/°C LT6654AIS6-2.5 –40°C to 85°C 0.1% 20ppm/°C LT6654BIS6-2.5 –40°C to 85°C 0.05% 10ppm/°C LT6654AHS6-2.5 –40°C to 125°C 0.05% 10ppm/°C LT6654AHLS8-2.5 –40°C to 125°C 0.1% 20ppm/°C LT6654BHS6-2.5 –40°C to 125°C 0.1% 20ppm/°C LT6654BHLS8-2.5 –40°C to 125°C 0.05% 10ppm/°C LT6654AMPS6-2.5 –55°C to 125°C 0.1% 20ppm/°C LT6654BMPS6-2.5 –55°C to 125°C 3V 0.05% 10ppm/°C LT6654AIS6-3 –40°C to 85°C 0.1% 20ppm/°C LT6654BIS6-3 –40°C to 85°C 0.05% 10ppm/°C LT6654AHS6-3 –40°C to 125°C 0.1% 20ppm/°C LT6654BHS6-3 –40°C to 125°C 0.05% 10ppm/°C LT6654AMPS6-3 –55°C to 125°C 0.1% 20ppm/°C LT6654BMPS6-3 –55°C to 125°C 3.3V 0.05% 10ppm/°C LT6654AIS6-3.3 –40°C to 85°C 0.1% 20ppm/°C LT6654BIS6-3.3 –40°C to 85°C 0.05% 10ppm/°C LT6654AHS6-3.3 –40°C to 125°C 0.1% 20ppm/°C LT6654BHS6-3.3 –40°C to 125°C 0.05% 10ppm/°C LT6654AMPS6-3.3 –55°C to 125°C 0.1% 20ppm/°C LT6654BMPS6-3.3 –55°C to 125°C 4.096V 0.05% 10ppm/°C LT6654AIS6-4.096 –40°C to 85°C 0.1% 20ppm/°C LT6654BIS6-4.096 –40°C to 85°C 0.05% 10ppm/°C LT6654AHS6-4.096 –40°C to 125°C 0.05% 10ppm/°C LT6654AHLS8-4.096 –40°C to 125°C 0.1% 20ppm/°C LT6654BHS6-4.096 –40°C to 125°C 0.1% 20ppm/°C LT6654BHLS8-4.096 –40°C to 125°C 0.05% 10ppm/°C LT6654AMPS6-4.096 –55°C to 125°C 0.1% 20ppm/°C LT6654BMPS6-4.096 –55°C to 125°C 5V 0.05% 10ppm/°C LT6654AIS6-5 –40°C to 85°C 0.1% 20ppm/°C LT6654BIS6-5 –40°C to 85°C 0.05% 10ppm/°C LT6654AHS6-5 –40°C to 125°C 0.05% 10ppm/°C LT6654AHLS8-5 –40°C to 125°C 0.1% 20ppm/°C LT6654BHS6-5 –40°C to 125°C 0.1% 20ppm/°C LT6654BHLS8-5 –40°C to 125°C 0.05% 10ppm/°C LT6654AMPS6-5 –55°C to 125°C 0.1% 20ppm/°C LT6654BMPS6-5 –55°C to 125°C ** See the Order Information section for complete part number listing. 6654fh 4 For more information www.linear.com/LT6654 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagrams Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
