Datasheet LT6654 (Analog Devices) - 10
DescriptionPrecision Wide Supply High Output Drive Low Noise Reference
Pages / Page22 / 10 — Typical. perForMance characTerisTics The characteristic curves are …
Typical. perForMance characTerisTics The characteristic curves are similar across the
Typical perForMance characTerisTics The characteristic curves are similar across the
LT6654
LT6654
Typical perForMance characTerisTics The characteristic curves are similar across the LT6654 family. Curves from the LT6654-1.25, LT6654-2.5 and the LT6654-5 represent the full range of typical performance of all voltage options. Characteristic curves for other output voltages fall between these curves and can be estimated based on their output. 2.5V Load Transient Response 5V Output Voltage Temperature 2.5V Long Term Drift (LS8) (Sinking) Drift
150 5.003 THREE TYPICAL PARTS 120 5.002 IOUT 90 5.001 5mA 60 5.000 0mA 30 TAGE (V) 4.999 0 4.998 PPM –30 4.997 VOUT –60 20mV/DIV/AC 4.996 2.5V/DC REFERENCE VOL –90 4.995 –120 4.994 –150 4.993 0 500 1000 1500 2000 50µs/DIV 6654 G27 –60 –40 –20 0 20 40 60 80 100 120 140 CLOAD = 1µF TIME (HOURS) TEMPERATURE (°C) 6654 G38 6654 G28
5V Output Impedance 5V Turn-On Characteristics vs Frequency 5V Load Regulation (Sourcing)
100 50 40 10 VIN 30 2V/DIV CL = 1µF 20 –55°C GND 1 TAGE CHANGE (ppm) 10 –40°C VOUT 0 125°C 2V/DIV OUTPUT IMPEDANCE (Ω) 0.1 CL = 10µF 25°C GND OUTPUT VOL –10 0.01 –20 50µs/DIV 6654 G29 0.1 1 10 100 1000 0.1 1 10 CLOAD = 1µF FREQUENCY (kHz) OUTPUT CURRENT (mA) 6654 G30 6654 G31
5V Minimum VIN to VOUT 5V Load Regulation (Sinking) 5V Output Noise 0.1Hz to 10Hz Differential (Sourcing)
220 10 200 –55°C 25°C 180 –40°C 160 140 V/DIV) 125°C 120 –55°C 1 TAGE CHANGE (ppm) 100 –40°C 80 125°C 60 25°C OUTPUT NOISE (4µ OUTPUT CURRENT (mA) 40 OUTPUT VOL 20 0 0.1 0.1 1 10 0 1 2 3 4 5 6 7 8 9 10 0 50 100 150 200 250 300 350 400 OUTPUT CURRENT (mA) TIME (1s/DIV) INPUT-OUTPUT VOLTAGE (mV) 6654 G32 6654 G33 6654 G34 6654fh 10 For more information www.linear.com/LT6654 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagrams Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
