Datasheet LT6656 (Analog Devices) - 10
Description1μA Precision Series Voltage Reference
Pages / Page24 / 10 — PIN FUNCTIONS (TSOT-23/DFN). (LS8). GND* (Pin 1/Pin 3):. NC (Pins 1, 2, …
File Format / SizePDF / 604 Kb
PIN FUNCTIONS (TSOT-23/DFN). (LS8). GND* (Pin 1/Pin 3):. NC (Pins 1, 2, 7):. GND (Pin 2/Pin 2):. GND* (Pin 3):
PIN FUNCTIONS (TSOT-23/DFN) (LS8) GND* (Pin 1/Pin 3): NC (Pins 1, 2, 7): GND (Pin 2/Pin 2): GND* (Pin 3):
LT6656
LT6656
Internal Function. This pin must be
NC (Pins 1, 2, 7):
Not Internally Connected. May be tied tied to ground. to VIN, VOUT, GND or floated.
GND (Pin 2/Pin 2):
Device Ground.
GND* (Pin 3):
Internal Function. This pin must be tied
NC (Pins 3, 5/Pins 1, 5):
Not Internally Connected. May to ground. be tied to VIN, VOUT, GND or floated.
GND (Pin 4):
Device Ground.
VIN (Pin 4/Pin 6):
Power Supply. The minimum supply
VOUT (Pin 5):
Output Voltage. A minimum output capacitor varies with output load and voltage option, see the Dropout of 1µF is required for stable operation. Voltage specification in the Electrical Characteristics table
V
for further details. The maximum input voltage is 18V.
OUT (Pin 6):
Output Voltage. Tie to pin 5 for best load regulation. Bypass VIN with a 0.1µF capacitor to ground.
V V IN (Pin 8):
Power Supply. Bypass VIN with a 0.1µF
OUT (Pin 6/Pin 4):
Output Voltage. A minimum output capacitor to ground. capacitor of 1µF is required for stable operation.
GND*(Exposed Pad Pin 7, DFN Only):
This pin must be tied to ground.
BLOCK DIAGRAM
8 TSOT-23/DFN VIN LS8 VIN NC 1 NC NC 7 V 2 NC OUT 6 VOUT VOUT 5 BANDGAP ERROR BANDGAP ERROR AMP AMP NC GND* GND GND* GND 3 4 6656 BD 6656 BD (LS8) 6656fc 10 For more information www.linear.com/LT6656 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
