Datasheet ADR360, ADR361, ADR363, ADR364, ADR365, ADR366 (Analog Devices)
DescriptionLow Power, Low Noise Voltage Reference with Sink/Source Capability, 3.3 VOUT
Pages / Page20 / 1 — Low Power, Low Noise Voltage References. with Sink/Source Capability. …
RevisionE
File Format / SizePDF / 545 Kb
Low Power, Low Noise Voltage References. with Sink/Source Capability. ADR360/ADR361/ADR363/ADR364/ADR365/ADR366. FEATURES
Datasheet ADR360, ADR361, ADR363, ADR364, ADR365, ADR366 Analog Devices, Revision: E
link to page 20 link to page 20 link to page 1
Low Power, Low Noise Voltage References with Sink/Source Capability ADR360/ADR361/ADR363/ADR364/ADR365/ADR366 FEATURES PIN CONFIGURATION Compact TSOT packages NC 1 5 Low temperature coefficient TRIM ADR36x B grade: 9 ppm/°C GND 2 TOP VIEW (Not to Scale) A grade: 25 ppm/°C V 3 4
1
IN VOUT Initial accuracy
00 7- 46
B grade: ±3 mV maximum NC = NO CONNECT
05
A grade: ±6 mV maximum
Figure 1. 5-Lead TSOT (UJ)
Ultralow output noise: 6.8 μV p-p (0.1 Hz to 10 Hz) Low dropout: 300 mV Table 1. ADR36x Family of Devices Low supply current: 190 μA maximum Temperature Coefficient (ppm/°C) No external capacitor required Model VOUT (V) 1 Accuracy (mV) Output current: +5 mA/−1 mA
ADR360B 2.048 9 ±3
Wide temperature range: −40°C to +125°C
ADR360A 2.048 25 ±6
Qualified for automotive applications
ADR361B 2.5 9 ±3 ADR361A 2.5 25 ±6
ADR363B 3.0 9 ±3
Battery-powered instruments
ADR363A 3.0 25 ±6
Portable medical instruments
ADR364B 4.096 9 ±4
Data acquisition systems
ADR364A 4.096 25 ±8
Industrial process controls
ADR365B 5.0 9 ±4
ADR365A 5.0 25 ±8 ADR366B 3.3 9 ±4 ADR366A 3.3 25 ±8 1 Contact Analog Devices for other voltage options.
GENERAL DESCRIPTION
The ADR360/ADR361/ADR363/ADR364/ADR365/ADR366 supply of 300 mV above the output. Their advanced design are precision 2.048 V, 2.5 V, 3.0 V, 4.096 V, 5.0 V, and 3.3 V band eliminates the need for external capacitors, which further gap voltage references that offer low power and high precision reduces board space and system cost. The combination of low in tiny footprints. Using patented temperature drift curvature power operation, small size, and ease of use makes the ADR36x correction techniques from Analog Devices, Inc., the ADR36x precision voltage references ideally suited for battery-operated references achieve a low temperature drift of 9 ppm/°C in a applications. TSOT package. See the Ordering Guide for automotive grades. The ADR36x family of micropower, low dropout voltage references provides a stable output voltage from a minimum
Rev. D Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2005–2010 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ADR360 ELECTRICAL CHARACTERISTICS ADR361 ELECTRICAL CHARACTERISTICS ADR363 ELECTRICAL CHARACTERISTICS ADR364 ELECTRICAL CHARACTERISTICS ADR365 ELECTRICAL CHARACTERISTICS ADR366 ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION DEVICE POWER DISSIPATION CONSIDERATIONS INPUT CAPACITOR OUTPUT CAPACITOR APPLICATIONS INFORMATION BASIC VOLTAGE REFERENCE CONNECTION Stacking Reference ICs for Arbitrary Outputs Negative Precision Reference Without Precision Resistors General-Purpose Current Source Trim Terminal OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
