Datasheet LT6650 (Analog Devices) - 2
DescriptionMicropower, 400mV Reference with Rail-to-Rail Buffer Amplifier in SOT-23
Pages / Page12 / 2 — ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). Order …
File Format / SizePDF / 458 Kb
ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). Order Options. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1) Order Options ELECTRICAL CHARACTERISTICS The
LT6650
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1)
TOP VIEW Total Supply Voltage (VIN to GND)... 20V FB Voltage (Note 2) ... 20V to (GND – 0.3V) FB 1 5 OUT Output Voltage (OUT) .. 20V to (GND – 0.3V) GND 2 DNC* 3 4 IN Output Short-Circuit Duration .. Indefinite FB Input Current ... 10mA S5 PACKAGE 5-LEAD PLASTIC TSOT-23 Operating Temperature Range ... –40°C to 125°C *Do Not Connect TJMAX = 150°C, θJA = 230°C/W Specified Temperature Range ORDER PART NUMBER S5 PART MARKING LT6650CS5 ... 0°C to 70°C LT6650IS5 ... –40°C to 85°C LT6650CS5 LBDV LT6650HS5 (Note 3) ... –40°C to 125°C LT6650IS5 LBDV Maximum Junction Temperature .. 150°C LT6650HS5 LBDV Storage Temperature Range (Note 4) .. –65°C to 150°C
Order Options
Tape and Reel: Add #TR Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Temperature (Soldering, 10 sec).. 300°C Lead Free Part Marking: http://www.linear.com/leadfree/ The temperature grades are identified by a label on the shipping container. Consult LTC Marketing for parts specified with wider operating temperature ranges.
C. VIN = 5V, CIN = 1
µ
F, FB = OUT, no DC load, CL = 1
µ
F, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOUT Output Voltage (Notes 4, 5) LT6650 398 400 402 mV –0.5 0.5 % LT6650CS5 ● 397 400 403 mV ● –0.75 0.75 % LT6650IS5 ● 396 400 404 mV ● –1 1 % LT6650HS5 ● 394 400 406 mV ● –1.5 1.5 % VIN Operating Input Voltage 1.4 18 V ∆VOUT/∆VIN Line Regulation 1.4V ≤ VIN ≤ 18V 1 6 mV 150 900 ppm/V LT6650CS5, LT6650IS5 ● 7.5 mV ● 1130 ppm/V LT6650HS5 ● 8.5 mV ● 1280 ppm/V ∆VOUT/∆IOUT Load Regulation (Note 6) Sourcing from 0µA to –200µA –0.04 –0.2 mV 500 2500 ppm/mA ● –0.4 mV ● 5000 ppm/mA Sinking from 0µA to 200µA 0.24 1 mV 3000 12500 ppm/mA ● 2 mV ● 20000 ppm/mA 6650fa 2
