Datasheet ADR01-EP (Analog Devices) - 3
DescriptionUltracompact, Precision 10.0 V Voltage Reference
Pages / Page8 / 3 — Data Sheet. ADR01-EP. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. …
File Format / SizePDF / 131 Kb
Data Sheet. ADR01-EP. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max
Data Sheet ADR01-EP SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 1 Parameter Symbol Test Conditions/Comments Min Typ Max
link to page 3
VIN = 12.0 V to 28.0 V, TA = 25°C, unless otherwise noted.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
OUTPUT VOLTAGE VO T grade 9.985 10.000 10.015 V INITIAL ACCURACY VOERR T grade 15 mV 0.15 % TEMPERATURE COEFFICIENT TCVO T grade, 5-lead TSOT, −55°C < TA < +125°C 25 ppm/°C DROPOUT VOLTAGE VDO 2 V LINE REGULATION ∆VO/∆VIN VIN = 12.0 V to 28.0 V, −55°C < TA < +125°C 7 30 ppm/V LOAD REGULATION ∆VO/∆ILOAD ILOAD = 0 mA to 10 mA, −55°C < TA < +125°C, 40 70 ppm/mA VIN = 15.0 V QUIESCENT CURRENT IIN No load, −55°C < TA < +125°C 0.65 1 mA VOLTAGE NOISE eN p-p 0.1 Hz to 10.0 Hz 20 µV p-p VOLTAGE NOISE DENSITY eN 1 kHz 510 nV/√Hz TURN-ON SETTLING TIME tR 4 µs LONG-TERM STABILITY1 ∆VO 1000 hours 50 ppm OUTPUT VOLTAGE HYSTERESIS ∆VO_HYS 70 ppm RIPPLE REJECTION RATIO RRR fIN = 10 kHz −75 dB SHORT CIRCUIT TO GND ISC 30 mA TEMPERATURE SENSOR Voltage Output at TEMP Pin VTEMP 550 mV Temperature Sensitivity TCVTEMP 1.96 mV/°C 1 The long-term stability specification is noncumulative. The drift in subsequent 1000 hour periods is significantly lower than in the first 1000 hour period. Rev. 0 | Page 3 of 8 Document Outline Features Enhanced Product Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Outline Dimensions Ordering Guide
