Datasheet LTC1258 (Analog Devices) - 4
DescriptionMicropower Low Dropout References
Pages / Page8 / 4 — ELECTRICAL CHARACTERISTICS Note 4:. Note 8:. Note 9:. Note 5:. Note 6:. …
File Format / SizePDF / 137 Kb
ELECTRICAL CHARACTERISTICS Note 4:. Note 8:. Note 9:. Note 5:. Note 6:. Note 7:. TYPICAL PERFORMANCE CHARACTERISTICS
ELECTRICAL CHARACTERISTICS Note 4: Note 8: Note 9: Note 5: Note 6: Note 7: TYPICAL PERFORMANCE CHARACTERISTICS
LTC1258 Series
ESD (electrostatic discharge) sensitive device. Extensive use of
Note 8:
Dropout voltage is (VIN – VOUT) when VOUT falls to 0.1% below its ESD protection devices are used internal to the LTC1258, however, high nominal value at VIN = VOUT + 0.5V. electrostatic discharge can damage or degrade the device. Use proper ESD
Note 9:
Hysteresis in output voltage is created by package stress that handling precautions. differs depending on whether the IC was previously at a higher or lower
Note 5:
Peak-to-peak noise is measured with a single pole highpass fi lter temperature. Output voltage is always measured at 25°C, but the IC is at 0.1Hz and 2-pole lowpass fi lter at 10Hz. cycled hot or cold before successive measurements. Hysteresis is not
Note 6:
Temperature coeffi cient is the change in output voltage divided by normally a problem for operational temperature excursions where the the nominal output voltage divided by the specifi ed temperature range. instrument might be stored at high or low temperature.
Note 7:
Load regulation is measured on a pulse basis from no load to the specifi ed load current. Output changes due to die temperature change must be taken into account separately.
TYPICAL PERFORMANCE CHARACTERISTICS LTC1258-2.5* Dropout Voltage vs LTC1258-2.5* Input Current vs LTC1258 Series Output Short- Output Source Current Temperature Circuit Current vs Temperature
100 8 70 T V T OUTPUT 90 A = 25oC IN = 2.7V A = 25°C 7 60 VIN = VOUT(NOM) + 0.2V SHORTED 80 TO GND 6 50 70 60 5 40 50 4 30 40 3 20 30 INPUT CURRENT (μA) DROPOUT VOLTAGE (mV) 2 10 OUTPUT 20 SHORTED TO V 10 1 5 IN OUTPUT SHORT-CIRCUIT CURRENT (mA) 0 0 0 0 0.1 1 10 100 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 OUTPUT SOURCE CURRENT (mA) TEMPERATURE (°C) TEMPERATURE (°C) 1258 G01 1258 G02 1258 G03
LTC1258-2.5* Output Short- LTC1258-2.5* Output Short- Circuit vs Input Voltage Circuit Current vs Input Voltage LTC1258 Series Load Regulation
25 42 5 T T A = 25°C A = 25°C 4 OUTPUT SHORTED VIN = VOUT(NOM) + 0.2V 20 TO VIN 3 SINKING 2 15 1 SOURCING 0 10 –1 FROM NO LOAD (mV) –2 OUTV 5 TA = 25°C $ –3 OUTPUT SHORTED OUTPUT SHORT-CIRCUIT CURRENT (mA) OUTPUT SHORT-CIRCUIT CURRENT (mA) TO GND –4 0 41 –5 2 4 6 8 10 12 14 2 4 6 8 10 12 14 0 0.1 1 10 100 INPUT VOLTAGE (V) INPUT VOLTAGE (V) OUTPUT CURRENT (mA) 1258-G04 1258-G05 1258 G06 *Similar performance characteristics can be expected for all voltage options. 1258sfb 4
