Datasheet AD1582, AD1583, AD1584, AD1585 (Analog Devices) - 10
Description | 5.0 V Micropower, Precision Series Mode Voltage Reference |
Pages / Page | 17 / 10 — AD1582/AD1583/AD1584/AD1585. Data Sheet. TYPICAL PERFORMANCE … |
Revision | M |
File Format / Size | PDF / 424 Kb |
AD1582/AD1583/AD1584/AD1585. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 0.40. 0.35. 0.30. AD1585. ART. 0.25. P F. /m 0.20. AD1582. R O
AD1582/AD1583/AD1584/AD1585 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 0.40 22 20 0.35 18 0.30 S 16 AD1585 ART 14 0.25 P F A 12 /m 0.20 AD1582 R O 10 mV BE 0.15 8 NUM 6 0.10 4 0.05 2 0 0
6
–60 –50 –40 –30 –20 –10 0 10 20 30 40 50
003
0 2 4 6 8 10 12
-00 01-
ppm/°C
01 07
V
0
IN (V)
07 0 Figure 3. Typical Output Voltage Temperature Drift Distribution Figure 6. Load Regulation vs. VIN
50 0 45 –10 40 –20 35 S –30 ART 30 P F –40 25 /V AD1582 R O µV –50 BE 20 –60 NUM 15 AD1585 –70 10 5 –80 0 –90
7
–1.0% –0.6% –0.2% 0.2% 0.6% 1.0%
04 0
–5 –4 –3 –2 –1 0 1 2 3 4 5
00 1- 1-
VOUT (ERROR)
70
IOUT (mA)
70 00 00 Figure 4. Typical Output Voltage Error Distribution Figure 7. Line Regulation vs. ILOAD
2.504 10k 2.502 2.500 2.498 IOUT = 1mA z T IOUT = 0mA 2.496 OU / H 1k V nV 2.494 2.492 2.490 2.488 100 –40 –20 0 20 40 60 80 100 120
05 0
10 100 1k 10k 100k
008 1- 1-
TEMPERATURE (°C)
070
FREQUENCY (Hz)
0 070 0 Figure 5. Typical Temperature Drift Characteristic Curves Figure 8. Noise Spectral Density Rev. L | Page 10 of 17 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AD1582 SPECIFICATIONS AD1583 SPECIFICATIONS AD1584 SPECIFICATIONS AD1585 SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION TEMPERATURE PERFORMANCE VOLTAGE OUTPUT NONLINEARITY VS. TEMPERATURE OUTPUT VOLTAGE HYSTERESIS SOLDER HEAT EFFECT SUPPLY CURRENT VS. TEMPERATURE SUPPLY VOLTAGE AC PERFORMANCE NOISE PERFORMANCE AND REDUCTION TURN-ON TIME DYNAMIC PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE APPLICATIONS
