Datasheet LT1236 (Analog Devices) - 2
Description | Precision Reference |
Pages / Page | 12 / 2 — ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHAR C. A … |
File Format / Size | PDF / 230 Kb |
ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHAR C. A TERISTICS VIN = 10V, IOUT = 0, TA = 25
LT1236
W W W U ABSOLUTE AXI U A R TI GS
Input Voltage .. 40V Output Short-Circuit Duration Input/Output Voltage Differential .. 35V VIN = 35V ... 10 sec Output-to-Ground Voltage (Shunt Mode Current Limit) VIN ≤ 20V ... Indefinite LT1236-5 ... 10V Operating Temperature Range LT1236-10 ... 16V LT1236AC, BC, CC .. 0°C to 70°C Trim Pin-to-Ground Voltage LT1236AI, BI, CI .. – 40°C to 85°C Positive.. Equal to VOUT Storage Temperature Range .. – 65°C to 150°C Negative ... – 20V Lead Temperature (Soldering, 10 sec) .. 300°C
U W U PACKAGE/ORDER I FOR ATIO
ORDER PART ORDER PART NUMBER NUMBER TOP VIEW TOP VIEW LT1236ACN8-5 LT1236ACS8-5 LT1236AIS8-5 NC* 1 8 NC* LT1236BCN8-5 NC* 1 8 NC* LT1236BCS8-5 LT1236BIS8-5 V 2 IN 7 NC* LT1236CCN8-5 V 2 LT1236CCS8-5 LT1236CIS8-5 IN 7 NC* NC* 3 6 V0UT LT1236ACN8-10 NC* 3 6 V LT1236ACS8-10 LT1236AIS8-10 0UT GND 4 5 TRIM** LT1236BCN8-10 GND 4 5 TRIM** LT1236BCS8-10 LT1236BIS8-10 LT1236CCN8-10 LT1236CCS8-10 LT1236CIS8-10 N8 PACKAGE S8 PACKAGE 8-LEAD PDIP LT1236AIN8-5 8-LEAD PLASTIC SO CONNECTED INTERNALLY. * LT1236BIN8-5 *CONNECTED INTERNALLY. S8 PART MARKING D0 NOT CONNECT EXTERNAL D0 NOT CONNECT EXTERNAL LT1236CIN8-5 CIRCUITRY TO THESE PINS CIRCUITRY TO THESE PINS 236AC5 236AI5 SEE APPLICATIONS ** LT1236AIN8-10 SEE APPLICATIONS ** INFORMATION SECTION 236BC5 236BI5 INFORMATION SECTION LT1236BIN8-10 T T 236CC5 236CI5 JMAX = 125°C, θJA = 130°C/ W JMAX = 125°C, θJA = 190°C/ W LT1236CIN8-10 236AC1 236AI1 236BC1 236BI1 236CC1 236CI1 Consult factory for Military grade parts.
ELECTRICAL CHAR C A TERISTICS VIN = 10V, IOUT = 0, TA = 25
C, unless otherwise noted. LT1236-5 PARAMETER CONDITIONS MIN TYP MAX UNITS
Output Voltage (Note 1) LT1236A-5 4.9975 5.000 5.0025 V LT1236B-5/LT1236C-5 4.9950 5.000 5.0050 V Output Voltage Temperature Coefficient (Note 2) TMIN ≤ TJ ≤ TMAX LT1236A-5 2 5 ppm/°C LT1236B-5 5 10 ppm/°C LT1236C-5 10 15 ppm/°C Line Regulation (Note 3) 7.2V ≤ VIN ≤ 10V 4 12 ppm/V ● 20 ppm/V 10V ≤ VIN ≤ 40V 2 6 ppm/V ● 10 ppm/V Load Regulation (Sourcing Current) 0 ≤ IOUT ≤ 10mA 10 20 ppm/mA (Note 3) ● 35 ppm/mA 2
