Datasheet LT1027 (Analog Devices) - 3
DescriptionPrecision 5 Volt Reference
Pages / Page8 / 3 — ELECTRICAL CH. ARA TERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 220 Kb
ELECTRICAL CH. ARA TERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CH ARA TERISTICS The denotes specifications which apply over the full operating
LT1027
ELECTRICAL CH C ARA TERISTICS The
denotes specifications which apply over the full operating temperature range otherwise specifications are at TA = 25
C. VIN = 10V, ILOAD = 0, unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Line Regulation (Note 4) 8V ≤ VIN ≤ 10V 6 12 ppm/V ● 25 ppm/V 10V ≤ VIN ≤ 40V 3 6 ppm/V ● 8 ppm/V Load Regulation (Notes 4, 6) Sourcing Current –8 –3 6 ppm/mA 0 ≤ IOUT ≤ 15mA ● –10 8 ppm/mA Sinking Current ● 30 120 ppm/mA 0 ≥ IOUT ≥ – 10mA Supply Current 2.2 3.1 mA ● 3.5 mA VTRIM Adjust Range ● ±30 ±50 mV en Output Noise (Note 5) 0.1Hz ≤ f ≤ 10Hz 3 µVP-P 10Hz ≤ f ≤ 1kHz 2.0 6.0 µVRMS Temperature Hysteresis H package; ∆T = 25°C 10 ppm Long Term Stability H package 20 ppm/month
Note 1:
Note 5:
RMS noise is measured with an 8-pole bandpass filter with a of the part may be impaired. center frequency of 30Hz and a Q of 1.5. The filter output is then rectified and integrated for a fixed time period, resulting in an average, as opposed
Note 2:
Output voltage is measured immediately after turn-on. Changes to RMS voltage. A correction factor is used to convert average to RMS. due to chip warm-up are typically less than 0.005%. This value is then used to obtain RMS noise voltage in the 10Hz to 1000Hz
Note 3:
Temperature coefficient is determined by the "box" method in frequency band. This test also screens for low frequency "popcorn" noise which the maximum ∆VOUT over the temperature range is divided by ∆T. within the bandwidth of the filter. Consult factory for 100% 0.1Hz to 10Hz
Note 4:
Line and load regulation measurements are done on a pulse basis. noise testing. Output voltage changes due to die temperature change must be taken into
Note 6:
Devices typically exhibit a slight negative DC output impedance of account separately. Package thermal resistance is 150°C/W for TO-5 (H), – 0.015Ω. This compensates for PC trace resistance, improving regulation 130°C/W for PDIP (N8), and 180°C/W for plastic SO (SO-8). at the load.
W U TYPICAL PERFOR A CE CH C ARA TERISTICS Ripple Rejection Output Impedance vs Frequency Output Voltage
100 100 5.006 V ∆I = ±3mA AC IN = 10V 120 ISOURCE = 5mA 5.004 110 ) Ω 10 5.002 100 90 1 5.000 80 REJECTION (dB) 4.998 OUTPUT VOLTAGE (V) 70 OUTPUT IMPEDANCE ( 0.1 4.996 60 0.01 50 4.994 10 100 1k 10k 10 100 1k 10k 100k 1M –50 –25 0 25 50 75 100 FREQUENCY (Hz) FREQUENCY (Hz) TEMPERATURE (°C) 1027 G01 1027 G02 1027 G03 sn1027 1027fcs 3
