Datasheet AD680 (Analog Devices) - 5
DescriptionBandgap, Low Power 2.5v Reference
Pages / Page12 / 5 — AD680. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. TP*. +VIN 2. TEMP. …
RevisionH
File Format / SizePDF / 402 Kb
AD680. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. TP*. +VIN 2. TEMP. TOP VIEW. VOUT. (Not to Scale). GND. NC = NO CONNECT
AD680 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TP* +VIN 2 TEMP TOP VIEW VOUT (Not to Scale) GND NC = NO CONNECT
AD680 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TP* 1 8 TP* +VIN 2 AD680 7 TP* TEMP 3 TOP VIEW 6 VOUT (Not to Scale) GND 4 5 NC NC = NO CONNECT * TP DENOTES FACTORY TEST POINT. NO CONNECTIONS SHOULD BE MADE TO THESE PINS.
00813-003 Figure 3. 8-Lead PDIP and 8-Lead SOIC Pin Configuration
AD680 BOTTOM VIEW (Not to Scale) 3 2 1 +VIN VOUT GND
00813-004 Figure 4. Connection Diagram
Table 3. Pin Function Descriptions Pin No. Mnemonic Descriptions
1, 7, 8 TP Test Point. A factory test point. No connections are made to these pins. 2 +VIN Input Voltage. 3 TEMP Temperature Output. 4 GND Ground. 5 NC No Connect. 6 VOUT Output Voltage. Rev. H | Page 5 of 12 Document Outline FEATURES GENERAL DESCRIPTION CONNECTION DIAGRAMS PRODUCT HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS OUTPUT PROTECTION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS THEORY OF OPERATION APPLYING THE AD680 NOISE PERFORMANCE TURN-ON TIME DYNAMIC PERFORMANCE LOAD REGULATION TEMPERATURE PERFORMANCE TEMPERATURE OUTPUT PIN DIFFERENTIAL TEMPERATURE TRANSDUCER LOW POWER, LOW VOLTAGE REFERENCE FOR DATA CONVERTERS 4.5 V REFERENCE FROM A 5 V SUPPLY VOLTAGE REGULATOR FOR PORTABLE EQUIPMENT OUTLINE DIMENSIONS ORDERING GUIDE
