Datasheet REF43 (Analog Devices) - 4
Description+2.5V Low Power Precision Voltage Reference
Pages / Page12 / 4 — REF43. DICE CHARACTERISTICS. VIN. TEMPERATURE OUT. 4A. GROUND* 4B. …
RevisionD
File Format / SizePDF / 979 Kb
REF43. DICE CHARACTERISTICS. VIN. TEMPERATURE OUT. 4A. GROUND* 4B. GROUND* 5. TRIM. 6A. VOUT FO2. VIN 6B. VOUT SENSE‡
REF43 DICE CHARACTERISTICS VIN TEMPERATURE OUT 4A GROUND* 4B GROUND* 5 TRIM 6A VOUT FO2 VIN 6B VOUT SENSE‡
REF43 DICE CHARACTERISTICS 2. VIN 3. TEMPERATURE OUT 4A. GROUND* 4B. GROUND* 5. TRIM 6A. VOUT FO2. VIN 6B. VOUT SENSE‡ *PADS 4A AND 4B MUST BOTH BE BONDED TO GROUND. ‡VOUT FORCE AND SENSE ARE TYPICALLY BONDED TOGETHER AT THE LOAD. DIE SIZE 0.085
0.062 inch, 5270 sq. mils (2.16
1.57 mm, 3.39 sq. mm)
–4– REV. D Document Outline FEATURES GENERAL DESCRIPTION PIN CONFIGURATION ORDERING GUIDE SIMPLIFIED SCHEMATIC ABSOLUTE MAXIMUM RATINGS ELECTRICAL CHARACTERISTICS BURN-IN CIRCUIT OUTPUT VOLTAGE TRIM METHOD DICE CHARACTERISTICS WAFER TEST LIMITS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION GENERATING A –2.5V REFERENCE BOOST TRANSISTOR PROVIDES HIGH OUTPUT CURRENT LOW POWER CMOS DAC REFERENCE PRECISION CURRENT SOURCE TEMPERATURE MEASUREMENT OUTLINE DIMENSIONS Revision History
