Datasheet LT1021 (Analog Devices) - 3
DescriptionPrecision Reference
Pages / Page16 / 3 — ELECTRICAL CH. ARA TERISTICS The. denotes specifications that apply over …
File Format / SizePDF / 239 Kb
ELECTRICAL CH. ARA TERISTICS The. denotes specifications that apply over the full operating temperature
ELECTRICAL CH ARA TERISTICS The denotes specifications that apply over the full operating temperature
LT1021
ELECTRICAL CH C ARA TERISTICS The
denotes specifications that apply over the full operating temperature range, otherwise specifications are TA = 25
C. VIN = 10V, IOUT = 0, unless otherwise noted. LT1021-5 PARAMETER CONDITIONS MIN TYP MAX UNITS
Output Voltage (Note 2) LT1021C-5 4.9975 5.000 5.0025 V LT1021B-5/LT1021D-5 4.9500 5.000 5.0500 V Output Voltage Temperature Coefficient (Note 3) TMIN ≤ TJ ≤ TMAX LT1021B-5 ● 2 5 ppm/°C LT1021C-5/LT1021D-5 ● 3 20 ppm/°C Line Regulation (Note 4) 7.2V ≤ VIN ≤ 10V 4 12 ppm/V ● 20 ppm/V 10V ≤ VIN ≤ 40V 2 6 ppm/V ● 10 ppm/V Load Regulation (Sourcing Current) 0 ≤ IOUT ≤ 10mA 10 20 ppm/mA (Note 4) ● 35 ppm/mA Load Regulation (Sinking Current) 0 ≤ IOUT ≤ 10mA 60 100 ppm/mA (Note 4) ● 150 ppm/mA Supply Current 0.8 1.2 mA ● 1.5 mA Output Voltage Noise (Note 6) 0.1Hz ≤ f ≤ 10Hz 3.0 µVP-P 10Hz ≤ f ≤ 1kHz 2.2 3.5 µVRMS Long Term Stability of Output Voltage (Note 7) ∆t = 1000Hrs Noncumulative 15 ppm Temperature Hysteresis of Output ∆T = ±25°C 10 ppm
The
C. VIN = 12V, IOUT = 0, unless otherwise noted. LT1021-7 PARAMETER CONDITIONS MIN TYP MAX UNITS
Output Voltage (Note 2) 6.95 7.00 7.05 V Output Voltage Temperature Coefficient (Note 3) TMIN ≤ TJ ≤ TMAX LT1021B-7 ● 2 5 ppm/°C LT1021D-7 ● 3 20 ppm/°C Line Regulation (Note 4) 8.5V ≤ VIN ≤ 12V 1.0 4 ppm/V ● 2.0 8 ppm/V 12V ≤ VIN ≤ 40V 0.5 2 ppm/V ● 1.0 4 ppm/V Load Regulation (Sourcing Current) 0 ≤ IOUT ≤ 10mA 12 25 ppm/mA (Note 4) ● 40 ppm/mA Load Regulation (Shunt Mode) 1.2mA ≤ ISHUNT ≤ 10mA 50 100 ppm/mA (Notes 4, 5) ● 150 ppm/mA Supply Current (Series Mode) 0.75 1.2 mA ● 1.5 mA Minimum Current (Shunt Mode) VIN is Open 0.7 1.0 mA ● 1.2 mA Output Voltage Noise (Note 6) 0.1Hz ≤ f ≤ 10Hz 4.0 µVP-P 10Hz ≤ f ≤ 1kHz 2.5 4.0 µVRMS Long Term Stability of Output Voltage (Note 7) ∆t = 1000Hrs Noncumulative 7 ppm Temperature Hysteresis of Output ∆T = ±25°C 3 ppm 1021fc 3
