Datasheet LTM8064 (Analog Devices) - 8
Description58VIN, 6A CVCC Step-Down μModule Regulator
Pages / Page36 / 8 — Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. …
File Format / SizePDF / 2.7 Mb
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Input Current vs Output Current. VOUT = –8V
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted Input Current vs Output Current VOUT = –8V
LTM8064
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Input Current vs Output Current Input Current vs Output Current Input Current vs Output Current VOUT = –8V VOUT = –12V VOUT = –18V
6 6 6 V V VIN = 3.3V 5 IN = 3.3V IN = 3.3V V 5 5 IN = 5V VIN = 5V VIN = 5V 4 VIN = 12V 4 VIN = 12V 4 VIN = 12V V V VIN = 24V 3 IN = 24V IN = 24V V 3 3 IN = 36V VIN = 36V VIN = 36V 2 VIN = 48V 2 2 1 1 1 0 0 0 –1 –1 –1 INPUT CURRENT (A) –2 INPUT CURRENT (A) –2 INPUT CURRENT (A) –2 –3 –3 –3 –4 –4 –4 –5 –5 –5 –5 –4 –3 –2 –1 0 1 2 3 4 5 –5 –4 –3 –2 –1 0 1 2 3 4 5 –4 –3 –2 –1 0 1 2 3 4 OUTPUT CURRENT (A) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 8064 G28 8064 G29 8064 G30
Input Current vs Output Current Input Current vs Output Current Input Current vs Input Voltage VOUT = –24V VOUT = –36V Output Shorted
7 6 1.2 V 6 IN = 3.3V VIN = 5V V 5 IN = 5V VIN = 12V 5 VIN = 12V 4 1.0 4 VIN = 24V 3 3 2 0.8 2 1 1 0.6 0 0 –1 –1 0.4 INPUT CURRENT (A) INPUT CURRENT (A) INPUT CURRENT (A) –2 –2 –3 –3 0.2 –4 –4 –5 –5 0 –3 –2 –1 0 1 2 3 –1.5 –1 –0.5 0 0.5 1 1.5 5 10 15 20 25 30 35 40 45 50 55 60 OUTPUT CURRENT (A) OUTPUT CURRENT (A) INPUT VOLTAGE (V) 8064 G31 8064 G32 8064 G33
Minimum Input Voltage Minimum Input Voltage Minimum Input Voltage vs Output Voltage, IOUT = 6A vs Output Voltage, VOUT = 5V vs Output Current, VOUT = 8V
60 7.0 10.0 55 50 45 6.5 9.5 TAGE (V) 40 TAGE (V) TAGE (V) 35 6.0 9.0 30 25 20 5.5 8.5 MINIMUM INPUT VOL 15 MINIMUM INPUT VOL MINIMUM INPUT VOL TO RUN 10 TO START 5 5.0 8.0 –5 0 5 10 15 20 25 0 1 2 3 4 5 6 0 1 2 3 4 5 6 OUTPUT VOLTAGE (V) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 8064 G34 8064 G35 8064 G36 8064fa 8 For more information www.linear.com/LTM8064 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
