Datasheet LTM8064 (Analog Devices) - 9
Description58VIN, 6A CVCC Step-Down μModule Regulator
Pages / Page36 / 9 — Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. …
File Format / SizePDF / 2.7 Mb
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Minimum Input Voltage. vs Output Current, VOUT = 12V
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted Minimum Input Voltage vs Output Current, VOUT = 12V
LTM8064
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Minimum Input Voltage Minimum Input Voltage Minimum Input Voltage vs Output Current, VOUT = 12V vs Output Current, VOUT = 18V vs Output Current, VOUT = 24V
14.0 20.2 26.6 20.0 26.4 13.5 TAGE (V) TAGE (V) TAGE (V) 19.8 26.2 13.0 19.6 26.0 12.5 MINIMUM INPUT VOL MINIMUM INPUT VOL 19.4 MINIMUM INPUT VOL 25.8 TO RUN TO START 12.0 19.2 25.6 0 1 2 3 4 5 6 0 1 2 3 4 5 6 0 1 2 3 4 5 6 OUTPUT CURRENT (A) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 8064 G37 8064 G38 8064 G39
Minimum Input Voltage Minimum Input Voltage Minimum Input Voltage vs Output Current, VOUT = 36V vs Output Current, VOUT = –3.3V vs Output Current, VOUT = –5V
41.5 27 55 TO RUN TO RUN 50 41.0 24 TO START TO START 45 21 40.5 40 TAGE (V) TAGE (V) 18 TAGE (V) 35 40.0 15 30 39.5 12 25 20 9 39.0 15 MINIMUM INPUT VOL 6 MINIMUM INPUT VOL MINIMUM INPUT VOL TO RUN 10 38.5 TO START 3 5 38.0 0 0 0 1 2 3 4 0 1 2 3 4 5 6 0 1 2 3 4 5 6 OUTPUT CURRENT (A) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 8064 G40 8064 G41 8064 G42
Minimum Input Voltage Minimum Input Voltage Minimum Input Voltage vs Output Current, VOUT = –8V vs Output Current, VOUT = –12V vs Output Current, VOUT = –18V
50 50 40 TO RUN TO RUN 45 TO RUN TO START 45 TO START 35 TO START 40 40 30 35 35 TAGE (V) TAGE (V) TAGE (V) 30 30 25 25 25 20 20 20 15 15 15 10 MINIMUM INPUT VOL 10 MINIMUM INPUT VOL 10 MINIMUM INPUT VOL 5 5 5 0 0 0 0 1 2 3 4 5 6 0 1 2 3 4 5 6 0 1 2 3 4 5 OUTPUT CURRENT (A) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 8064 G43 8064 G44 8064 G45 8064fa For more information www.linear.com/LTM8064 9 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
