Datasheet LTM8064 (Analog Devices) - 10
Description58VIN, 6A CVCC Step-Down μModule Regulator
Pages / Page36 / 10 — Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. …
File Format / SizePDF / 2.7 Mb
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Derating Curve. Minimum Input Voltage
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted Derating Curve Minimum Input Voltage
LTM8064
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Derating Curve Minimum Input Voltage Minimum Input Voltage V vs Output Current, V vs Output Current, V OUT = 1.8V OUT = –24V OUT = –36V
35 25 7 TO RUN TO RUN TO START 30 TO START 6 20 25 5 TAGE (V) TAGE (V) 20 15 4 15 10 3 CURRENT (A) 10 2 V MINIMUM INPUT VOL MINIMUM INPUT VOL 5 IN = 12V 5 VIN = 24V 1 VIN = 36V V 0 0 IN = 48V 0 0 1 2 3 4 0 0.5 1 1.5 2 2.5 0 25 50 75 100 125 OUTPUT CURRENT (A) OUTPUT CURRENT (A) AMBIENT TEMPERATURE (°C) 8064 G46 8064 G47 8064 G48
Derating Curve Derating Curve Derating Curve VOUT = 2.5V VOUT = 3.3V VOUT = 5V
7 7 7 6 6 6 5 5 5 4 4 4 3 3 3 CURRENT (A) CURRENT (A) CURRENT (A) 2 2 2 VIN = 12V VIN = 12V VIN = 12V VIN = 24V 1 VIN = 24V VIN = 24V V 1 1 IN = 36V VIN = 36V VIN = 36V VIN = 48V V V 0 IN = 48V 0 IN = 48V 0 0 25 50 75 100 125 0 25 50 75 100 125 0 25 50 75 100 125 AMBIENT TEMPERATURE (°C) AMBIENT TEMPERATURE (°C) AMBIENT TEMPERATURE (°C) 8064 G49 8064 G50 8064 G51
Derating Curve Derating Curve Derating Curve VOUT = 8V VOUT = 12V VOUT = 18V
7 7 7 6 6 6 5 5 5 4 4 4 3 3 3 CURRENT (A) CURRENT (A) CURRENT (A) 2 2 2 VIN = 12V V V V IN = 24V 1 IN = 24V 1 IN = 24V 1 V V V IN = 36V IN = 36V IN = 36V V V V IN = 48V IN = 48V IN = 48V 0 0 0 0 25 50 75 100 125 0 25 50 75 100 125 0 25 50 75 100 125 AMBIENT TEMPERATURE (°C) AMBIENT TEMPERATURE (°C) AMBIENT TEMPERATURE (°C) 8064 G52 8064 G53 8064 G54 8064fa 10 For more information www.linear.com/LTM8064 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
