Datasheet LTM4634 (Analog Devices) - 3
DescriptionTriple Output 5A/5A/4A Step-Down DC/DC μModule (Power Module) Regulator
Pages / Page32 / 3 — elecTrical characTerisTics. The. denotes the specifications which apply …
File Format / SizePDF / 759 Kb
elecTrical characTerisTics. The. denotes the specifications which apply over the specified internal
elecTrical characTerisTics The denotes the specifications which apply over the specified internal
LTM4634
denotes the specifications which apply over the specified internal operating temperature range (Note 2), otherwise specifications are at TA = 25°C. VIN = 24V, per the typical application for each regulator channel. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Input DC Voltage CNTL_PWR Powered Tied to Input Supply l 4.75 28 V VOUT(RANGE) Output Voltage Range VOUT1, VOUT2 l 0.8 5.5 V Output Voltage Range VOUT3 l 0.8 13.5 V VOUT(DC) Output Voltage, Total Variation with Line CIN = 22µF × 3, COUT = 100µF Ceramic × 3, l 4.925 5.0 5.075 V and Load, VOUT1, VOUT2, VOUT3 RFB = 11.5k, MODE/PLLIN = 0V, VIN = 5.5V to 28V, IOUT1,2 = 0A to 5A, IOUT3 = 0A to 4A (Note 4)
Input Specifications
VRUN RUN1, RUN2, RUN3 Pin ON Threshold VRUN Rising 1.15 1.3 1.4 V VRUN(HYS) RUN Pin Hysteresis 175 mV IQ(VIN) Input Supply Bias Current Each Channel VOUT = 5V, Burst Mode Operation, IOUT = 0A 0.5 mA VOUT = 5V, Pulse-Skipping Mode, IOUT = 0A 1.6 mA VOUT = 5V, Switching Continuous, IOUT = 0A 45 mA Shutdown, RUN = 0V, VIN = 24V 10 µA IS(VIN) Input Supply Current Each Channel VIN = 12V, EXTVCC = 5VOUT IOUT1,2 = 5A 2.21 A VOUT1,2 = 5V, VOUT3 = 5V IOUT3 = 4A 1.76 A
Output Specifications (Note 4)
IOUT(DC) Output Continuous Current Range Each VOUT1,2 = 5V 0 5 A Channel VOUT3 = 5V 0 4 A ∆VOUT(LINE) Line Regulation Accuracy per Channel VOUT1 = VIN from 5.5V to 28V l 0.015 0.02 %/V I VOUT OUT = 0A, CNTL_PWR Tie to VIN ∆VOUT(LOAD) Load Regulation Accuracy per Channel VOUT = 5V, IOUT1,2 = 0A to 5A l 0.3 0.5 % Ch1, Ch2, I VOUT OUT3 = 0A to 4A VOUT(AC) Output Ripple Voltage per Channel IOUT = 0A, COUT = 100µF Ceramic × 3, 75 mV VIN = 24V, VOUT = 5V ∆VOUT(START) Turn-On Overshoot per Channel COUT = 100µF Ceramic × 3, VOUT = 5V, 50 mV IOUT = 0A, TK/SS = 0.01µF tSTART Turn-On Time per Channel COUT = 100µF Ceramic × 3, VOUT = 5V, 6 ms IOUT = 0A, TK/SS = 0.01µF VOUTLS Peak Deviation for Dynamic Load per Load: 0% to 50% to 0% of Full Load, 200 mV Channel COUT = 100µF Ceramic × 3, VOUT = 5V Typical Bench Data tSETTLE Settling Time for Dynamic Load Step per Load: 0% to 50% to 0% of Full Load, 50 µs Channel COUT = 100µF Ceramic × 3, VOUT = 5V Typical Bench Data IOUT(PK) Output Current Limit per Channel VOUT = 5V 8 A
Control Specifications
VFB Voltage at VFB Pin per Channel IOUT = 0A, VOUT = 5V 0.794 0.80 0.806 V l 0.792 0.80 0.808 V IFB Current at VFB Pin per Channel (Note 3) –10 –50 nA VOVL Feedback Overvoltage Lockout per l 0.84 0.86 0.88 V Channel ITK/SS Track Pin Soft-Start Pull-Up Current per TK/SS = 0V 1.1 1.5 1.9 µA Channel tON(MIN) Minimum On-Time (Note 3) 90 ns Max DC Maximum Duty Cycle 5.5V to 5V at 5A (Note 5) 95 % RFBHI Resistor Between VOUT and VFB Pins 60.0 60.4 60.8 kΩ 4634f For more information www.linear.com/LTM4634 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Related Parts
