Datasheet LTM8026 (Analog Devices) - 7
Description | 36VIN, 5A CVCC Step-Down µModule Regulator |
Pages / Page | 28 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. TA = 25°C, unless otherwise noted. … |
File Format / Size | PDF / 432 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. TA = 25°C, unless otherwise noted. Configured per Table 1, where applicable
LTM8026
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Configured per Table 1, where applicable. Input Current vs Load Current Input Current vs Load Current Minimum Required Input Running –8VOUT –12VOUT Voltage vs Negative Output Voltage
3.0 3.5 25 12VIN 12VIN IOUT = 4A 24VIN 24VIN IOUT = 3A 2.5 28V 3.0 IN I 20 OUT = 2A IOUT = 1A 2.5 2.0 2.0 15 1.5 1.5 10 INPUT CURRENT (A) 1.0 INPUT CURRENT (A) 1.0 INPUT VOLTAGE (V) 0.5 5 0.5 0 0 0 0 1 2 3 4 5 0 1 2 3 4 5 0 –5 –10 –15 OUTPUT CURRENT (A) OUTPUT CURRENT (A) OUTPUT VOLTAGE (V) 8026 G28 8026 G29 8026 G30
Minimum Required Input Running Voltage vs Output Voltage, Minimum Required Input Voltage Minimum Required Input Voltage IOUT = 5A vs Load 3.3VOUT and Below vs Load 5VOUT
30 6.4 7.2 25 6.2 7.0 20 15 6.0 6.8 INPUT VOLTAGE (V) 10 INPUT VOLTAGE (V) INPUT VOLTAGE (V) 5.8 6.6 5 0 5.6 6.4 0 5 10 15 20 25 30 0 1 2 3 4 5 0 1 2 3 4 5 OUTPUT VOLTAGE (V) LOAD CURRENT (A) LOAD CURRENT (A) 8026 G32 8026 G33 8026 G31
Minimum Required Input Voltage Minimum Required Input Voltage Minimum Required Input Voltage vs Load 8VOUT vs Load 12VOUT vs Load 18VOUT
10.0 14.4 21.5 14.2 9.8 21.0 14.0 9.6 20.5 13.8 9.4 20.0 INPUT VOLTAGE (V) INPUT VOLTAGE (V) 13.6 INPUT VOLTAGE (V) 9.2 19.5 13.4 9.0 13.2 19.0 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 LOAD CURRENT (A) LOAD CURRENT (A) LOAD CURRENT (A) 8026 G34 8026 G35 8026 G36 8026fd For more information www.linear.com/LTM8026 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Package Photo Package Description Revision History Typical Application Design Resources Related Parts
