Datasheet LTM8031 (Analog Devices) - 5
Description | Ultralow Noise EMC 36V, 1A DC/DC µModule Regulator |
Pages / Page | 22 / 5 — Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. … |
File Format / Size | PDF / 304 Kb |
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Minimum VIN vs Output Current
LTM8031
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Minimum VIN vs Output Current Minimum Input Running Voltage 8V VOUT vs Output Voltage, IOUT = 1A Bias Current vs Output Current
12 16 35 8VOUT 11 14 5VOUT RUN/SS = V 30 IN 3.3VOUT 10 12 25 9 RUNNING OR RUN/SS TOGGLED 10 20 (V) 8 (V) 8 V IN V IN 15 7 6 BIAS CURRENT (mA) 10 6 4 5 2 5 4 0 0 0 200 400 600 800 1000 0 2 4 6 8 10 0 200 400 600 800 1000 OUTPUT CURRENT (mA) VOUT (V) OUTPUT CURRENT (mA) 8031 G10 8031 G11 8031 G12
Output Current vs Input Voltage Input Current vs Input Voltage Temperature Rise vs (Output Shorted) (Output Shorted) Load Current, VOUT = 3.3V
2.75 1.4 30 36VIN 2.70 1.2 24VIN 25 12VIN 2.65 5VIN 1.0 20 2.60 0.8 2.55 15 0.6 2.50 10 OUTPUT CURRENT (A) INPUT CURRENT (A) 0.4 2.45 TEMPERATURE RISE (°C) 5 2.40 0.2 2.35 0 0 0 4 8 12 16 20 24 28 32 36 0 10 20 30 40 0 200 400 600 800 1000 VIN (V) VIN (V) OUTPUT CURRENT (mA) 8031 G13 8031 G14 8031 G15
Temperature Rise vs Temperature Rise vs Temperature Rise vs Load Current, VOUT = 5V Load Current, VOUT = 8V Load Current, VOUT = 10V
30 30 30 36VIN 36VIN 36VIN 24VIN 24VIN 24V 25 IN 12VIN 25 12VIN 25 20 20 20 15 15 15 10 10 10 TEMPERATURE RISE (°C) TEMPERATURE RISE (°C) TEMPERATURE RISE (°C) 5 5 5 0 0 0 1 200 400 600 800 1000 1 200 400 600 800 1000 1 200 400 600 800 1000 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) 8031 G16 8031 G17 8031 G18 8031fb 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical application Related Parts
