Datasheet LTM8027 (Analog Devices) - 4
Description60V, 4A DC/DC µModule Regulator
Pages / Page22 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS (TA = 25°C unless otherwise noted). …
File Format / SizePDF / 636 Kb
TYPICAL PERFORMANCE CHARACTERISTICS (TA = 25°C unless otherwise noted). Efficiency vs Load, VOUT = 2.5V
TYPICAL PERFORMANCE CHARACTERISTICS (TA = 25°C unless otherwise noted) Efficiency vs Load, VOUT = 2.5V
LTM8027
TYPICAL PERFORMANCE CHARACTERISTICS (TA = 25°C unless otherwise noted) Efficiency vs Load, VOUT = 2.5V Efficiency vs Load, VOUT = 3.3V Efficiency vs Load, VOUT = 5V
100 100 100 90 90 90 80 80 80 70 70 70 60 60 60 50 50 50 40 40 40 EFFICIENCY (%) EFFICIENCY (%) 5VIN EFFICIENCY (%) 30 30 12V 30 12VIN 5V IN 24V 20 IN 24V IN 12V IN IN 20 36V 20 36V IN IN 10 24VIN 10 48V 10 48VIN 36V IN IN 60V 60V IN IN 0 0 0 0 1 2 3 4 0 1 2 3 4 0 1 2 3 4 LOAD (A) LOAD (A) LOAD (A) 8027 G01 8027 G02 8027 G03
Efficiency vs Load, VOUT = 8V Efficiency vs Load, VOUT = 12V Efficiency vs Load, VOUT = 15V
100 100 100 90 90 90 80 80 80 70 70 70 60 60 60 50 50 50 40 40 40 EFFICIENCY (%) EFFICIENCY (%) EFFICIENCY (%) 30 12VIN 30 30 24V 24V 24V 20 IN IN IN 36V 20 20 IN 36VIN 36VIN 10 48VIN 10 48VIN 10 48VIN 60VIN 60VIN 60VIN 0 0 0 0 1 2 3 4 0 1 2 3 4 0 1 2 3 4 LOAD (A) LOAD (A) LOAD (A) 8027 G04 8027 G05 8027 G06
Input Current Efficiency vs Load, VOUT = 18V Efficiency vs Load, VOUT = 24V vs VIN Output Shorted
100 100 1.2 90 90 80 80 1.0 70 70 0.8 60 60 50 50 0.6 40 40 EFFICIENCY (%) EFFICIENCY (%) 30 30 INPUT CURRENT (A) 0.4 24V 20 IN 36V 20 IN 36VIN 0.2 10 48VIN 10 48VIN 60VIN 60VIN 0 0 0 0 1 2 3 4 0 1 2 3 4 0 10 20 30 40 50 60 70 LOAD (A) LOAD (A) INPUT VOLTAGE (V) 8027 G07 8027 G08 8027 G09 8027fd 4 For more information www.linear.com/LTM8027 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Photograph Package Description Revision History Typical Application Related Parts
