Datasheet LTM4616 (Analog Devices) - 2
Description | Dual 8A per Channel Low VIN DC/DC µModule Regulator |
Pages / Page | 30 / 2 — absolute. bsolute Maxi. Maxi u. M M. M r. atings. (Note 1). pin … |
File Format / Size | PDF / 792 Kb |
absolute. bsolute Maxi. Maxi u. M M. M r. atings. (Note 1). pin conFiguration. orDer inForMation. PART NUMBER. PAD OR BALL FINISH
LTM4616
absolute a bsolute Maxi M Maxi u M M u M r atings r (Note 1)
VIN1, SVIN1, VIN2, SVIN2 .. –0.3V to 6V VOUT1, VOUT2, SW1, SW2 .. –0.3V to VIN CLKOUT1, CLKOUT2 .. –0.3V to 2V Internal Operating Temperature Range (Note 2) PGOOD1, PLLLPF1, CLKIN1, PHMODE1, E- and I-Grades .. –40°C to 125°C MODE1, PGOOD2, PLLLPF2, CLKIN2, MP-Grade .. –55°C to 125°C PHMODE2, MODE2 ... –0.3V to VIN Junction Temperature ... 125°C ITH1, ITHM1, RUN1, FB1, TRACK1, MGN1, Storage Temperature Range .. –55°C to 125°C BSEL1, ITH2, ITHM2, RUN2, FB2, TRACK2, MGN2, BSEL2 ... –0.3V to VIN
pin conFiguration
TOP VIEW TOP VIEW SGND2 CLKOUT2 SGND2 CLKOUT2 RUN2 I V RUN2 I TH2 IN2 TH2 VOUT2 VIN2 VOUT2 M M SVIN2 TRACK2 SVIN2 TRACK2 L L PLLLPF2 ITHM2 PLLLPF2 ITHM2 K K FB2 FB2 J J SW2 GND2 SW2 GND2 H H MODE2 MODE2 CLKIN2 PHMODE2 CLKIN2 PHMODE2 G G BSEL2 PGOOD2 BSEL2 PGOOD2 RUN1 MGN2 RUN1 MGN2 F F I SV ITH1 SV SGND1 TH1 IN1 SGND1 CLKOUT1 IN1 CLKOUT1 E TRACK1 E TRACK1 PLLLPF1 I PLLLPF1 THM1 ITHM1 D VOUT1 D VOUT1 VIN1 VIN1 C C SW1 FB1 SW1 FB1 B GND1 B GND1 BSEL1 BSEL1 PGOOD1 PGOOD1 A A MGN1 MGN1 1 2 3 4 5 6 7 8 9 10 11 12 1 2 3 4 5 6 7 8 9 10 11 12 CLKIN1 MODE1 PHMODE1 CLKIN1 MODE1 PHMODE1 LGA PACKAGE BGA PACKAGE 144-LEAD (15mm × 15mm × 2.82mm) 144-LEAD (15mm × 15mm × 3.42mm) TJMAX = 125°C, θJA = 10.5°C/W, θJCbottom = 2°C/W, θJCtop = 16°C/W, WEIGHT = 1.8g TJMAX = 125°C, θJA = 10.5°C/W, θJCbottom = 2°C/W, θJCtop = 16°C/W, WEIGHT = 2.0g θJA DERIVED FROM 95mm × 76mm PCB WITH 4 LAYERS θJA DERIVED FROM 95mm × 76mm PCB WITH 4 LAYERS
orDer inForMation PART NUMBER PAD OR BALL FINISH PART MARKING* PACKAGE MSL TEMPERATURE RANGE TYPE RATING (Note 2) DEVICE FINISH CODE
LTM4616EV#PBF Au (RoHS) LTM4616V e4 LGA 3 –40°C to 125°C LTM4616IV#PBF Au (RoHS) LTM4616V e4 LGA 3 –40°C to 125°C LTM4616MPV#PBF Au (RoHS) LTM4616V e4 LGA 3 –55°C to 125°C LTM4616EY#PBF SAC305 (RoHS) LTM4616Y e1 BGA 3 –40°C to 125°C LTM4616IY#PBF SAC305 (RoHS) LTM4616Y e1 BGA 3 –40°C to 125°C LTM4616IY SnPb (63/37) LTM4616Y e0 BGA 3 –40°C to 125°C LTM4616MPY#PBF SAC305 (RoHS) LTM4616Y e1 BGA 3 –55°C to 125°C LTM4616MPY SnPb (63/37) LTM4616Y e0 BGA 3 –55°C to 125°C Consult Marketing for parts specified with wider operating temperature • Recommended LGA and BGA PCB Assembly and Manufacturing ranges. *Device temperature grade is indicated by a label on the shipping Procedures: container. Pad or ball finish code is per IPC/JEDEC J-STD-609. www.linear.com/umodule/pcbassembly • Pb-free and Non-Pb-free Part Markings: • LGA and BGA Package and Tray Drawings: www.linear.com/leadfree www.linear.com/packaging 4616ff 2 For more information www.linear.com/LTM4616 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Simplified Block Diagram Operation Applications Information Package Description Revision History Package Photo Related Parts Design Resources
