Datasheet LTM4601AHV (Analog Devices) - 2
Description12A, 28VIN DC/DC µModule Regualtor with PLL, Output Tracking and Margining
Pages / Page30 / 2 — absoluTe MaxiMuM raTings. (Note 1). pin conFiguraTion. orDer inForMaTion. …
absoluTe MaxiMuM raTings. (Note 1). pin conFiguraTion. orDer inForMaTion. PART NUMBER. PAD OR BALL FINISH. PART MARKING*. PACKAGE. MSL
absoluTe MaxiMuM raTings (Note 1) pin conFiguraTion orDer inForMaTion PART NUMBER PAD OR BALL FINISH PART MARKING* PACKAGE MSL
LTM4601AHV
INTV + – CC, DRVCC, VOUT_LCL, VOUT (VOUT ≤ 3.3V with VOSNS , VOSNS ..–0.3V to INTVCC + 0.3V Remote Sense Amp) .. –0.3V to 6V Operating Temperature Range (Note 2) PLLIN, TRACK/SS, MPGM, MARG0, MARG1, E and I Grades ...–40°C to 85°C PGOOD, fSET ..–0.3V to INTVCC + 0.3V MP Grade ... –55°C to 125°C RUN ... –0.3V to 5V Junction Temperature ... 125°C VFB, COMP .. –0.3V to 2.7V Storage Temperature Range .. –55°C to 125°C VIN ... –0.3V to 28V
pin conFiguraTion
TOP VIEW TOP VIEW V CC V CC INT PLLIN TRACK/SS RUN COMP MPGM INT PLLIN TRACK/SS RUN COMP MPGM VIN fSET VIN fSET MTP1 MTP1 MARG0 MARG0 MTP2 MTP2 MARG1 MARG1 INTVCC INTVCC MTP3 DRVCC MTP3 DRVCC PGND VFB PGND VFB PGOOD PGOOD SGND SGND V + + OSNS VOSNS DIFFVOUT DIFFVOUT VOUT V V OUT OUT_LCL VOUT_LCL V – – OSNS VOSNS BGA PACKAGE LGA PACKAGE 133-LEAD (15mm × 15mm × 3.42mm) 133-LEAD (15mm × 15mm × 2.82mm) TJMAX = 125°C, θJA = 15.5°C/W, θJCbottom = 6.5°C/W TJMAX = 125°C, θJA = 15°C/W, θJCbottom = 6°C/W θJA DERIVED FROM 95mm × 76mm PCB WITH 4 LAYERS θJA DERIVED FROM 95mm × 76mm PCB WITH 4 LAYERS WEIGHT = 1.9g WEIGHT = 1.7g
orDer inForMaTion PART NUMBER PAD OR BALL FINISH PART MARKING* PACKAGE MSL TEMPERATURE RANGE TYPE RATING (Note 2) DEVICE FINISH CODE
LTM4601AHVEV#PBF Au (RoHS) LTM4601AHVV e4 LGA 3 –40°C to 125°C LTM4601AHVIV#PBF Au (RoHS) LTM4601AHVV e4 LGA 3 –40°C to 125°C LTM4601AHVMPV#PBF Au (RoHS) LTM4601AHVMPV e4 LGA 3 –55°C to 125°C LTM4601AHVEY#PBF SAC305 (RoHS) LTM4601AHVY e1 BGA 3 –40°C to 125°C LTM4601AHVIY#PBF SAC305 (RoHS) LTM4601AHVY e1 BGA 3 –40°C to 125°C LTM4601AHVIY SnPb (63/37) LTM4601AHVY e0 BGA 3 –40°C to 125°C LTM4601AHVMPY#PBF SAC305 (RoHS) LTM4601AHVMPY e1 BGA 3 –55°C to 125°C LTM4601AHVMPY SnPb (63/37) LTM4601AHVMPY e0 BGA 3 –55°C to 125°C Consult Marketing for parts specified with wider operating temperature • Recommended LGA and BGA PCB Assembly and Manufacturing ranges. *Device temperature grade is indicated by a label on the shipping Procedures: container. Pad or ball finish code is per IPC/JEDEC J-STD-609. www.linear.com/umodule/pcbassembly • Terminal Finish Part Marking: • LGA and BGA Package and Tray Drawings: www.linear.com/leadfree www.linear.com/packaging 4601ahvfc 2 For more information www.linear.com/LTM4601AHV Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Operation Applications Information Typical Applications Package Description Revision History Package Photos Related Parts
