Datasheet LTM8020 (Analog Devices)
Description200mA, 36V DC/DC µModule Regulator
Pages / Page16 / 1 — FEATURES. DESCRIPTION. Complete Step-Down Switch Mode Power Supply. Wide …
File Format / SizePDF / 406 Kb
FEATURES. DESCRIPTION. Complete Step-Down Switch Mode Power Supply. Wide Input Voltage Range: 4V to 36V
Datasheet LTM8020 Analog Devices
LTM8020 200mA, 36V DC/DC µModule Regulator
FEATURES DESCRIPTION
n
The LTM®8020 is a complete 200mA, DC/DC step-down n
power supply. Included in the package are the switch- n
1.25V to 5V Output Voltage
ing controller, power switches, inductor, and all support n
EN55022 Class B Compliant
components. Operating over an input voltage range of 4V n 200mA Output Current to 36V, the LTM8020 supports an output voltage range of n Current Mode Control 1.25V to 5V, set by a single resistor. Only bulk capacitors n –55°C to 125°C Operating Temperature are needed to finish the design. The LTM8020 meets the (LTM8020MPV) radiated emissions requirements of EN55022. Conducted n Pb-Free (e4) RoHS Compliant Package with Gold Pad emission requirements can be met by adding standard Finish filter components. n Tiny, Low Profile (6.25mm × 6.25mm × 2.32mm) The low profile (2.32mm) tiny package enables utilization Surface Mount LGA Package of unused space on the bottom of PC boards for high density point of load regulation.
The LTM8020 is packaged in a thermally enhanced, n Automotive Battery Regulation compact (6.25mm × 6.25mm) and low profile (2.32mm) n Power for Portable Products over-molded land grid array (LGA) package suitable for n Distributed Supply Regulation automated assembly by standard surface mount equip- n Industrial Supplies ment. The LTM8020 is Pb-free and RoHS compliant. n L, LT, LTC, LTM, µModule, Linear Technology, the Linear logo and Burst Mode are registered Wall Transformer Regulation trademarks of Analog Devices, Inc. All other trademarks are the property of their respective owners.
TYPICAL APPLICATION 6.5VIN to 36VIN, 5V at 200mA DC/DC µModule
Regulator Efficiency and Power Loss vs Load Current
V 90 1000 IN V V OUT *6.5V TO 36V IN VOUT 5V LTM8020 80 2.2µF 200mA SHDN BIAS 70 100 POWER LOSS (mW) 10µF GND ADJ 60 165k 50 10 1% EFFICIENCY (%) 40 8020 TA01 30 1 *RUNNING VOLTAGE RANGE. PLEASE REFER TO APPLICATIONS INFORMATION 20 FOR START-UP DETAILS 10 0.1 0.1 1 10 100 LOAD CURRENT (mA) 3470 TA01b 8020fe For more information www.linear.com/LTM8020 1
