Datasheet LT4363 (Analog Devices) - 6
DescriptionHigh Voltage Surge Stopper with Current Limit
Pages / Page24 / 6 — Typical. perForMance characTerisTics Specifications are at VCC = 12V, TA …
File Format / SizePDF / 255 Kb
Typical. perForMance characTerisTics Specifications are at VCC = 12V, TA = 25°C, unless. otherwise noted
Typical perForMance characTerisTics Specifications are at VCC = 12V, TA = 25°C, unless otherwise noted
LT4363
Typical perForMance characTerisTics Specifications are at VCC = 12V, TA = 25°C, unless otherwise noted. Gate Drive vs Temperature Gate Drive vs Supply Voltage TMR High Threshold vs (ΔVGATE vs Temperature) (ΔVGATE vs VCC) Supply Voltage
14 16 5 VCC = SNS = OUT 14 I I GATE = 0µA GATE = 0µA 13 12 4 10 (V) IGATE = –1µA (V) IGATE = 1µA (V) TE 12 TE 8 3 GA GA ∆V ∆V V TMR 6 11 4 2 2 VCC = SNS = OUT 10 0 1 –50 –25 0 25 50 75 100 125 0 4 8 12 16 20 60 70 80 0 10 20 30 40 50 60 70 80 TEMPERATURE (°C) VCC (V) VCC (V) 4363 G10 4363 G11 4363 G12
Overvoltage TMR Current vs Overcurrent TMR Current vs Warning Period TMR Current (VCC – VOUT) (VCC – VOUT) vs VCC
–50 –260 –7 TMR = 1V TMR = 1V ∆VDS = 0.5V –220 –40 –6 –160 (µA) –30 (µA) (µA) –5 V) C) O O EW P, P, –120 U V, (U (O –20 –4 I TMR( I TMR –80 I TMR –10 –3 –40 0 0 –2 0 10 20 30 40 50 60 70 80 0 10 20 30 40 50 60 70 80 0 10 20 30 40 50 60 70 80 VCC – VOUT (V) VCC – VOUT (V) VCC (V) 4363 G13 4363 G14 4363 G15
TMR Pull-Down Current vs TMR Pull-Up Current (Cool Down) Temperature vs Temperature Output Low Voltage vs Current
2.4 –3.0 6 TMR = 1V TMR = 3V OUT = SNS = 3V 2.0 –2.5 5 1.6 –2.0 4 (µA) (µA) L) O 1.2 (V) –1.5 3 P,CO V OL (U I TMR(DN) 0.8 –1.0 2 I TMR 0.4 –0.5 1 0 0 0 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 0 0.5 1.0 1.5 2.0 2.5 3.0 TEMPERATURE (°C) TEMPERATURE (°C) ISINK (mA) 4363 G16 4363 G17 4363 G18 4363fb 6 For more information www.linear.com/LT4363 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Application Related Parts
