LTC4002 UUUPI FU CTIO S (DFN/SO-8) hot temperature or rises above 2.465V at cold temperature, disable the temperature qualification function, ground the charging is suspended and the internal timer stops. The NTC pin. CHRG pin output is not affected during this hold state. To NC (Pin 10/NA): No Connect. WBLOCK DIAGRA VCC CLK: 100µA I I SLOP L COMP DRIVER – GATE S Q CPWM R 25mV or 10mV R + + + – RSLOP CEOC – RIL 100mV SENSE + – + M1 CA – BAT + M2 VA – 4.2V/CELL + M3 CLB – 2.9V OR 5V 90µA + COV UVLO – 4.62V/CELL 4.2V + UV EOC + CSD SD RQ CRQ 360mV – – 4.05V/CELL LOGIC CHRG Q4 C/10 + 2.465V V Q5 STOP TEMP C CC COLD NTC_DISABLE – 85µA NTC 25µA – C GND HOT + 355mV + 4002 BD – 50mV 4002f 9
