Datasheet SRE (Songle Relay)
ManufacturerSongle Relay
DescriptionDouble Group Conversion Relay 1A/3A/5A
Pages / Page2 / 1 — SRE. Series. DOUBLE. GROUP. CONVERSION. RELAY. 1A/3A/5A. 22.6MAX. C. US. …
File Format / SizePDF / 3.9 Mb
SRE. Series. DOUBLE. GROUP. CONVERSION. RELAY. 1A/3A/5A. 22.6MAX. C. US. X. Features. A. 17M. E167996. ·Miniature. volume,. PCB. usage. X. A. ·Contact
Datasheet SRE Songle Relay
SRE Series DOUBLE GROUP CONVERSION RELAY 1A/3A/5A 22.6MAX C US X Features A 17M E167996 ·Miniature volume, PCB usage X A ·Contact rating:1A/3A/5A M .6 9 ·Double group individual load 1 Ordering Information Contact Rating SRE-12VDC-S L-2C Contact a rrangment 2 A / 2 B / 2 C Contact resistance 100mΩ (1A 6VDC) 2A/2B/ 2C Contact material Silver alloy:AgCdO、AgSnO2、AgNi Contact arrangment L0.45W / D0.80W Contact rating 1A/125VAC 3A/125VAC 5A/125VAC Coil Power Max switching voltage 250VAC S sealed / F dustproof Construction Max switching current 5A 5V / 6V / 9V / 12V Max switching power 625VA 18V / 24V Coil Voltage Electrical endurance (frequency: 1800 ops/h) 1x10 5ops / 1x10 4 ops Part number endurance Mechanical 1x10 o 7 ps (frequency: 18000 ops/h) Characteristics Coil Data ( 20 at ℃) Insulation system B Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 50MΩ (500VDC) W VDC mA ± Ω 10% voltage voltage allowable nim Dielectric Between contacts 1000VAC 1 minute 05 90 55.5 Strength and coil Leakage current Between open 06 75 80 750VAC 1 minute 1mA contacts 09 50 180 Operate time(Under nominal voltage) ≤10ms 0.45W 12 37.5 320 75%Max 5%Min 130% Release time(Under nominal voltage) ≤10ms ( L ) 18 25 720 Humidity 85% RH(20℃) 24 18.75 1280 - Ambient Temperature 40℃~+55℃/-40℃~+85℃ 05 160 31.2 Functional 98m/s
²
Shock 06 133 45 resistance Destructive 980m/s
²
09 88 101.2 Vibration resistance 10Hz
55Hz 1
5mm ( Double amplitude) 0.80W 12 66 180 80%Max 10%Min 130% Approx 12g Weight ( D ) 18 44 405 Sealed 24 33 720 Construction Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2
