Datasheet ADE7759 (Analog Devices) - 6
DescriptionActive Energy Metering IC with di/dt Sensor Interface
Pages / Page36 / 6 — ADE7759. ABSOLUTE MAXIMUM RATINGS*. ORDERING GUIDE. Model. Package …
File Format / SizePDF / 472 Kb
ADE7759. ABSOLUTE MAXIMUM RATINGS*. ORDERING GUIDE. Model. Package Option*. CAUTION. WARNING!. ESD SENSITIVE DEVICE
ADE7759 ABSOLUTE MAXIMUM RATINGS* ORDERING GUIDE Model Package Option* CAUTION WARNING! ESD SENSITIVE DEVICE
(TA = 25∞C unless otherwise noted) AV
DD to AGND . –0.3 V to +7 V DVDD to DGND . –0.3 V to +7 V ADE7759ARS RS-20 DVDD to AVDD . –0.3 V to +0.3 V ADE7759ARSRL RS-20 Analog Input Voltage to AGND EVAL-ADE7759EB ADE7759 Evaluation Board V1P, V1N, V2P, and V2N . –6 V to +6 V Reference Input Voltage to AGND . –0.3 V to AV
RS = Shrink Small Outline Package in tubes; RSRL = Shrink Small DD + 0.3 V Outline Package in reel. Digital Input Voltage to DGND . –0.3 V to DVDD + 0.3 V Digital Output Voltage to DGND . –0.3 V to DVDD + 0.3 V Operating Temperature Range Industrial (A, B Versions) . –40∞C to +85∞C Storage Temperature Range . –65∞C to +150∞C Junction Temperature . 150∞C 20-Lead SSOP, Power Dissipation . 450 mW qJA Thermal Impedance . 112∞C/W Lead Temperature, Soldering Vapor Phase (60 sec) . 215∞C Infrared (15 sec) . 220∞C *Stresses above those listed under Absolute Maximum Ratings may cause perma- nent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those listed in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although
WARNING!
the ADE7759 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are
recommended to avoid performance degradation or loss of functionality. –6– REV. A Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS TERMINOLOGY MEASUREMENT ERROR PHASE ERROR BETWEEN CHANNELS POWER SUPPLY REJECTION ADC OFFSET ERROR GAIN ERROR GAIN ERROR MATCH Typical Performance Characteristics Test Circuits ANALOG INPUTS di/dt CURRENT SENSOR AND DIGITAL INTEGRATOR ZERO CROSSING DETECTION LINE VOLTAGE SAG DETECTION Sag Level Set POWER SUPPLY MONITOR INTERRUPTS Using the ADE7759 Interrupts with an MCU Interrupt Timing TEMPERATURE MEASUREMENT ANALOG-TO-DIGITAL CONVERSION Antialias Filter ADC Transfer Function Reference Circuit CHANNEL 1 ADC Channel 1 ADC Gain Adjust Channel 1 Sampling CHANNEL 1 AND CHANNEL 2 WAVEFORM SAMPLING MODE CHANNEL 2 ADC Channel 2 Sampling PHASE COMPENSATION ACTIVE POWER CALCULATION ENERGY CALCULATION Integration Time under Steady Load POWER OFFSET CALIBRATION ENERGY-TO-FREQUENCY CONVERSION LINE CYCLE ENERGY ACCUMULATION MODE CALIBRATING THE ENERGY METER Calculating the Average Active Power Calibrating the Frequency at CF Energy Meter Display CLKIN FREQUENCY SUSPENDING THE ADE7759 FUNCTIONALITY APPLICATION INFORMATION SERIAL INTERFACE Serial Write Operation Serial Read Operation CHECKSUM REGISTER REGISTER DESCRIPTIONS Communications Register Mode Register (06H) Interrupt Status Register (04H) Reset Interrupt Status Register (05H) CH1OS Register (08H) OUTLINE DIMENSIONS Revision History
