Datasheet ADR5040, ADR5041, ADR5043, ADR5044, ADR5045 (Analog Devices)
DescriptionPrecision Micropower Shunt Mode Voltage Reference Applications (5.0 Vout)
Pages / Page15 / 1 — Precision Micropower Shunt Mode. Voltage References. Data Sheet. …
RevisionD
File Format / SizePDF / 451 Kb
Precision Micropower Shunt Mode. Voltage References. Data Sheet. ADR5040/. ADR5041. /ADR5043. /ADR5044/. ADR5045. FEATURES
Datasheet ADR5040, ADR5041, ADR5043, ADR5044, ADR5045 Analog Devices, Revision: D
Precision Micropower Shunt Mode Voltage References Data Sheet ADR5040/ ADR5041 /ADR5043 /ADR5044/ ADR5045 FEATURES PIN CONFIGURATION Ultracompact SC70 and SOT-23 packages ADR5040/ADR5041/ ADR5043/ADR5044/ Low temperature coefficient: 75 ppm/°C (maximum) ADR5045 Pin compatible with LM4040/LM4050 Initial accuracy: ±0.1% V+ 1 No external capacitor required 3 NC Wide operating current range: 50 µA to 15 mA V– 2 Extended temperature range: −40°C to +125°C Qualified for automotive applications NOTES 1. NC = NO CONNECT.
001
APPLICATIONS 2. PIN 3 MUST BE LEFT FLOATING OR CONNECTED TO GROUND.
06526-
Portable, battery-powered equipment
Figure 1. 3-Lead SC70 (KS) and 3-Lead SOT-23 (RT)
Automotives Power supplies Data acquisition systems Instrumentation and process control Energy management GENERAL DESCRIPTION
Designed for space-critical applications, the ADR5040/
Table 1. Selection Table
ADR5041/ADR5043/ADR5044/ADR5045 are high precision
Temperature
shunt voltage references, housed in ultrasmal SC70 and SOT-23
Initial Coefficient
packages. These voltage references are multipurpose, easy-to-use
Device Voltage (V) Accuracy (%) (ppm/°C)
references that can be used in a vast array of applications. They ADR5040A 2.048 ±0.2 100 feature low temperature drift, an initial accuracy of better than ADR5040B 2.048 ±0.1 75 0.1%, and fast settling time. ADR5041A 2.5 ±0.2 100 Available in output voltages of 2.048 V, 2.5 V, 3.0 V, 4.096 V, and ADR5041B 2.5 ±0.1 75 5.0 V, the advanced design of the ADR5040/ADR5041/ADR5043/ ADR5043A 3.0 ±0.2 100 ADR5044/ADR5045 eliminates the need for compensation by an ADR5043B 3.0 ±0.1 75 external capacitor, yet the references are stable with any capacitive ADR5044A 4.096 ±0.2 100 load. The minimum operating current increases from 50 µA to ADR5044B 4.096 ±0.1 75 a maximum of 15 mA. This low operating current and ease of use ADR5045A 5.0 ±0.2 100 make these references ideal y suited for handheld, battery-powered ADR5045B 5.0 ±0.1 75 applications. This family of references has been characterized over the extended temperature range of −40°C to +125°C. The ADR5041W and the ADR5044W are qualified for automotive applications and are available in a 3-lead SOT-23 package.
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2007–2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Pin Configuration General Description Revision History Specifications ADR5040 Electrical Characteristics ADR5041 Electrical Characteristics ADR5043 Electrical Characteristics ADR5044 Electrical Characteristics ADR5045 Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Terminology Theory of Operation Applications Information Precision Negative Voltage Reference Stacking the ADR5040/ADR5041/ADR5043/ADR5044/ADR5045 for User-Definable Outputs Adjustable Precision Voltage Source Programmable Current Source Outline Dimensions Ordering Guide Automotive Products
