Datasheet ADR5040, ADR5041, ADR5043, ADR5044, ADR5045 (Analog Devices) - 6
DescriptionPrecision Micropower Shunt Mode Voltage Reference Applications (5.0 Vout)
Pages / Page15 / 6 — ADR5040/ADR5041/ADR5043/ADR5044/ADR5045. Data Sheet. ABSOLUTE MAXIMUM …
RevisionD
File Format / SizePDF / 451 Kb
ADR5040/ADR5041/ADR5043/ADR5044/ADR5045. Data Sheet. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 7. Parameter. Rating
ADR5040/ADR5041/ADR5043/ADR5044/ADR5045 Data Sheet ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 7 Parameter Rating
Ratings apply at 25°C, unless otherwise noted.
THERMAL RESISTANCE
θ
Table 7.
JA is specified for the worst-case conditions, that is, a device soldered in a circuit board for surface-mount packages.
Parameter Rating
Reverse Current 25 mA
Table 8. Thermal Resistance
Forward Current 20 mA
Package Type θJA θJC Unit
Storage Temperature Range −65°C to +150°C 3-Lead SC70 (KS) 580.5 177.4 °C/W Extended Temperature Range −40°C to +125°C 3-Lead SOT-23 (RT) 270 102 °C/W Junction Temperature Range −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C Stresses at or above those listed under Absolute Maximum
ESD CAUTION
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. D | Page 6 of 15 Document Outline Features Applications Pin Configuration General Description Revision History Specifications ADR5040 Electrical Characteristics ADR5041 Electrical Characteristics ADR5043 Electrical Characteristics ADR5044 Electrical Characteristics ADR5045 Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Terminology Theory of Operation Applications Information Precision Negative Voltage Reference Stacking the ADR5040/ADR5041/ADR5043/ADR5044/ADR5045 for User-Definable Outputs Adjustable Precision Voltage Source Programmable Current Source Outline Dimensions Ordering Guide Automotive Products
