Datasheet LT6023, LT6023-1 (Analog Devices) - 10
DescriptionDual Micropower, 1.4V/μs Precision Rail-to-Rail Output Amplifier
Pages / Page22 / 10 — TYPICAL. PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, RL = 100kΩ …
File Format / SizePDF / 784 Kb
TYPICAL. PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, RL = 100kΩ unless. otherwise specified. Shutdown Supply Current vs
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, RL = 100kΩ unless otherwise specified Shutdown Supply Current vs
LT6023/LT6023-1
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, RL = 100kΩ unless otherwise specified. Shutdown Supply Current vs Supply Current vs Supply Voltage Temperature Start-Up Response
40 2 35 VS 20V/DIV 30 1.5 0V 25 I+ Y CURRENT (µA) 5mA/DIV 20 1 0mA 15 VS = ±15V 0V VOUT Y CURRENT PER AMPLIFIER (µA) 10 125°C 0.5 2V/DIV 85°C VS = ±1.5V VS = ±10V SUPP 5 25°C SHUTDOWN SUPPL AV = 1 –40°C VIN = 1V 0 0 0 5 10 15 20 25 30 –50 –25 0 25 50 75 100 125 200µs/DIV TOTAL SUPPLY VOLTAGE (V) TEMPERATURE (°C) 6023 G26 6023 G27 6023 G28
Output Saturation Voltage vs Output Saturation Voltage vs Enable/Disable Response Sink Current (Output Low) Source Current (Output High)
1 1 VEN 5V/DIV TAGE (V) TAGE (V) 0V I+ TION VOL TION VOL 40µA/DIV 0.1 0.1 TURA TURA 0µA VOUT 5V/DIV T T 0V A = 125°C A = 125°C TA = 85°C TA = 85°C T T OUTPUT LOW SA A = 25°C A = 25°C T OUTPUT HIGH SA A = –40°C TA = –40°C 0.01 0.01 500µs/DIV 0.1 1 10 0.1 1 10 LOAD CURRENT (mA) LOAD CURRENT (mA) 6023 G29 6023 G30 6023 G31
Positive Output Overdrive Negative Output Overdrive Crosstalk vs Frequency Recovery Recovery
0 –20 –40 INPUT OUTPUT 200mV/DIV 5V/DIV –60 0V ALK (dB) –80 0V CROSST OUTPUT –100 INPUT 5V/DIV 200mV/DIV –120 AV = 100 AV = 100 –14010 100 1k 10k 100k 1M 2ms/DIV 2ms/DIV FREQUENCY (Hz) 6023 G32 6023 G33 6023 G34 60231fa 10 For more information www.linear.com/LT6023 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Applications Information Typical Applications Package Description Typical Application Related Parts
