Datasheet LTC6091 (Analog Devices) - 4
DescriptionDual 140V, Rail-to-Rail Output, Picoamp Input Current Op Amp
Pages / Page22 / 4 — ELECTRICAL. CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 553 Kb
ELECTRICAL. CHARACTERISTICS The. denotes the specifications which apply over the full operating
LTC6091
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. Test conditions are V+ = 70V, V– = –70V, VCM = VOUT = 0V, VOD = open unless otherwise noted. I-SUFFIX H-SUFFIX SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
ODH OD Pin Voltage, Referenced to VIH l COM + COM + V COM Pin 1.8V 1.8V ODL OD Pin Voltage, Referenced to VIL l COM + COM + V COM Pin 0.65V 0.65V Amplifier DC Output DC, OD = COM >10 >10 MΩ Impedance, Disabled COMCM COM Pin Voltage Range l V– V+ – 5 V– V+ – 5 V COMV COM Pin Open-Circuit Voltage l 17 21 25 17 21 25 V COMR COM Pin Resistance l 500 665 850 500 665 850 kΩ TEMPF Die Temperature Where 145 145 °C TFLAG Is Active TEMPHYS TFLAG Output Hysteresis 5 5 °C ITFLAG TFLAG Pull-Down Current TFLAG Output l 70 200 330 70 200 330 µA Voltage = 0V
Note 1:
Note 4:
The LTC6091I is guaranteed to meet specified performance may cause permanent damage to the device. Exposure to any Absolute from –40°C to 85°C. The LTC6091H is guaranteed to meet specified Maximum Rating condition for extended periods may affect device performance from –40°C to 125°C. reliability and lifetime.
Note 5:
This device includes overtemperature protection that is intended
Note 2:
Either output (OUTA or OUTB) of the LTC6091 is capable of to protect the device during momentary overload conditions. Operation producing peak output currents in excess of 50mA. Current density above the specified maximum operating junction temperature is not limitations within the IC require the continuous RMS current supplied by recommended. either output (sourcing or sinking) over the operating lifetime of the part to
Note 6:
Input bias and offset current is production tested with ±15V be limited to under 50mA (absolute maximum). Proper heat sinking may supplies. See Typical Performance Characteristics curves of actual typical be required to keep the junction temperature below the absolute maximum performance over full supply range. rating. Refer to the Power Dissipation and Thermal Considerations section of the data sheet for more information.
Note 3:
The LTC6091I is guaranteed functional over the operating junction temperature range –40°C to 85°C. The LTC6091H is guaranteed functional over the operating junction temperature range –40°C to 125°C. Specifying the junction temperature range as an operating condition is applicable for devices with potentially significant quiescent power dissipation. 6091fa 4 For more information www.linear.com/LTC6091 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
