Datasheet LTC6087, LTC6088 (Analog Devices) - 3
DescriptionDual/Quad 14MHz, Rail-to-Rail CMOS Amplifiers
Pages / Page16 / 3 — ORDER INFORMATION. (http://www.linear.com/product/LTC6087-X#orderinfo). …
File Format / SizePDF / 308 Kb
ORDER INFORMATION. (http://www.linear.com/product/LTC6087-X#orderinfo). LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ORDER INFORMATION (http://www.linear.com/product/LTC6087-X#orderinfo) LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC6087/LTC6088
ORDER INFORMATION (http://www.linear.com/product/LTC6087-X#orderinfo) LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC6087CDD#PBF LTC6087CDD#TRPBF LCTX 10-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C LTC6087HDD#PBF LTC6087HDD#TRPBF LCTX 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC6087CMS8#PBF LTC6087CMS8#TRPBF LTCTY 8-Lead Plastic MSOP –40°C to 85°C LTC6087HMS8#PBF LTC6087HMS8#TRPBF LTCTY 8-Lead Plastic MSOP –40°C to 125°C LTC6088CDHC#PBF LTC6088CDHC#TRPBF 6088 16-Lead (5mm × 3mm) Plastic DFN –40°C to 85°C LTC6088HDHC#PBF LTC6088HDHC#TRPBF 6088 16-Lead (5mm × 3mm) Plastic DFN –40°C to 125°C LTC6088CGN#PBF LTC6088CGN#TRPBF 6088 16-Lead Plastic SSOP –40°C to 85°C LTC6088HGN#PBF LTC6088HGN#TRPBF 6088H 16-Lead Plastic SSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix.
l
denotes the specifications which apply over the full specified temperature range, otherwise specifications are at TA = 25°C. Test conditions are V+ = 3V, V– = 0V, VCM = 0.5V unless otherwise noted. C SUFFIX H SUFFIX SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Offset Voltage (Note 5) LTC6087MS8, LTC6088GN ±330 ±750 ±330 ±750 µV LTC6087DD, LTC6088DHC ±330 ±1100 ±330 ±1100 µV LTC6087MS8, LTC6088GN l ±900 ±1100 µV LTC6087DD, LTC6088DHC l ±1350 ±1600 µV ∆VOS/∆T Input Offset Voltage Drift (Note 6) LTC6087MS8, LTC6088GN l ±2 ±5 ±2 ±5 µV/°C LTC6087DD, LTC6088DHC l ±2 ±5 ±2 ±5 µV/°C IB Input Bias Current (Notes 5, 7) Guaranteed by 5V Test 1 1 pA l 40 500 pA IOS Input Offset Current (Notes 5, 7) Guaranteed by 5V Test 0.5 0.5 pA l 30 150 pA en Input Noise Voltage Density f = 1kHz 12 12 nV/√Hz f = 10kHz 10 10 nV/√Hz Input Noise Voltage 0.1Hz to 10Hz 2.5 2.5 µVP-P in Input Noise Current Density (Note 8) f = 1Hz 0.56 0.56 fA/√Hz Input Common Mode Range l V– V+ V– V+ V CIN Input Capacitance f = 100kHz Differential Mode 2.7 2.7 pF Common Mode 4.2 4.2 pF CMRR Common Mode Rejection Ratio 0V ≤ VCM ≤ 3V 64 80 64 80 dB l 63 61 dB PSRR Power Supply Rejection Ratio VS = 2.7V to 5.5V 93 115 93 115 dB l 90 85 dB VOUT Output Voltage, High (Referred to V+) No Load l 5 15 5 20 mV ISOURCE = 1mA l 25 50 25 50 mV ISOURCE = 5mA l 120 210 120 230 mV Output Voltage, Low (Referred to V–) No Load l 5 25 5 30 mV ISINK = 1mA l 25 50 25 60 mV ISINK = 5mA l 120 210 120 240 mV 60878fd For more information www.linear.com/LTC6087 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Simplified Schematic Package Description Revision History Typical Applications Related Parts
